Blow Hard - Router Forums
post #1 of 31 (permalink) Old 01-02-2015, 04:23 PM Thread Starter
Default Blow Hard
Has anyone used anemometers for quantifying their DC airflow?
As has been pointed out previously, the more fast flowing air the better(?)...
I'm thinking maybe measure the airflow at the actual inlets...simply hold in front of the hose opening(s)? Won't give CFM but knowing the airspeed might be helpful?
DaninVan is online now
post #2 of 31 (permalink) Old 01-02-2015, 04:33 PM
First Name: Al
Was almost afraid to open this thread up,lol
Sorry Dan,curious but clueless on this subject
al m is offline
post #3 of 31 (permalink) Old 01-02-2015, 04:40 PM
go w/ a manometer instead...
measure static ...
consult chart...
be given CFM...
it will also tell you when you filters need servicing...
install a vacuum gage at the DC...
post #4 of 31 (permalink) Old 01-02-2015, 05:38 PM
schnewj's Avatar
Actually there is a conversion formula...don't ask me what it is I'd have to go look it up. (I subscribe to the Albert Einstein theory of memory... "never remember anything you can look up".)
My Hygienists used to have to do CFM measurements to certify our fume hoods, and we used them to measure max wind speed when we moved hardware outside of the plant.
Stick has the best solution...hail Stick... His solution is a lot cheaper then a GOOD quality meter.
Bill
schnewj is offline
post #5 of 31 (permalink) Old 01-02-2015, 06:26 PM
about 10/15 bucks...
post #6 of 31 (permalink) Old 01-02-2015, 07:16 PM Thread Starter
$15...now we're talkin'!
post #7 of 31 (permalink) Old 01-02-2015, 07:16 PM
So if you find an answer how will you know what it means and what are you prepared to do to the DC if you think it's lacking?
post #8 of 31 (permalink) Old 01-02-2015, 07:24 PM Thread Starter
Charles; I think my objective is to have a baseline reading with everything clean and no obstructions. Something to indicate when efficiency has dropped significantly, and also to show when a particular collection port isn't doing the job. That's sort of why I got interested in the anemometer; I thought it might be a great diagnostic tool, but Stick says I'm out to lunch...well actually he said I was hogging the brewskis, but I knew what he meant.
post #9 of 31 (permalink) Old 01-02-2015, 07:41 PM
Huh???
post #10 of 31 (permalink) Old 01-02-2015, 07:42 PM
what's on the menu???
cat and moose hopefully...
Alternative to thin plywood - thin hard plastic? bobbotron Starting Off 10 05-18-2012 11:14 AM
Have you ever wondered how a hard drive works? harrysin Lobby 32 06-20-2011 01:13 AM
What is 'Hard Board' farrout Tools and Woodworking 6 10-09-2009 04:16 PM
Air hose mounted blow gun kp91 Tool Reviews 5 08-22-2009 02:28 AM
Pattern Routing With Hard Wood -- Safely!!! richnj General Routing 8 12-20-2008 09:32 PM
