I did a Dumb Thing - Router Forums
post #1 of 5 (permalink) Old 01-02-2015, 11:36 PM Thread Starter
Default I did a Dumb Thing
Sometimes a bright idea doesn't work and I feel like a dumb a**.
I had the bright idea to turn my Bosch router base into a Power Lift on my new router table.
I had this little Skil low speed driver I use for installing drawer guides in cabinets , so you guessed it why not chuck up a hex bit and use it to raise and lower my router?
So that I did , and when i was playing with it ,up &down, up & down, ..........Clunk....wiiiiiiiizzzzz. router not moving.
I pulled the router out of the table and spent an hour trying to figure out what went wrong. What I eventually found was that the router lift on the shaft has a spring washer that fits in a groove on the shaft. this little item was missing and the groove was all goud-up. Now what to do!
I looked around the junk cans and jars and found a concrete insert with a threaded stud in it. I removed the stud and drill out the threads the size of the shaft on the router.
Then I drilled and tapped a set screw on each side and installed it on the shaft and clamped it tight with the set screws.
Works great, not with the driver tho, with the hand key.
Name:	IMG_1811 (640x480).jpg
Name:	IMG_1810 (640x480).jpg
Name:	IMG_1807 (640x480).jpg
Name:	IMG_1809 (640x480).jpg
Herb Stoops is online now
post #2 of 5 (permalink) Old 01-02-2015, 11:46 PM
nice recovovery...
post #3 of 5 (permalink) Old 01-03-2015, 04:54 AM
I think Harry says, "necessity is the mother of inventiom"
Good recovery.
Sydney, Australia
jw2170 is offline
post #4 of 5 (permalink) Old 01-03-2015, 11:03 AM
GregLittleWoodworks's Avatar
First Name: Greg
A little imagination and thought goes a long way...nice save
“Each step of every Wood Art project I design and build is considered my masterpiece… because I want the finished product to reflect the quality and creativeness of my work. I study each piece to get ideas and details that will evolve in my future creations.
GregLittleWoodworks is offline
post #5 of 5 (permalink) Old 01-03-2015, 12:24 PM
First Name: Danella
No need to feel like a dumb ape. The end result is what matters.
beemor is offline
Whats the first thing that comes to mind? Mark Word Games 1601 07-09-2018 02:46 PM
A Funny Thing Happened At Home Depot CanuckGal Deb's Gallery 33 11-27-2009 02:51 PM
Dumb Question Melvin Table-mounted Routing 15 11-18-2009 08:06 AM
This is VERY coolest thing that I have EVER seen Bonehead V.2 Lobby 5 09-12-2009 11:50 PM
A funny thing happen reible Lobby 4 04-02-2005 01:14 PM
