trueing up a square - Router Forums
post #1 of 8 (permalink) Old 01-07-2015, 12:08 PM Thread Starter
paduke's Avatar
Default trueing up a square
I purchased the woodpecker precision triangle set shown below. I knew the 12" rafter square i owned was not true and had a thought to use my disc sander to true it up It seems to have worked
paduke is offline
post #2 of 8 (permalink) Old 01-07-2015, 12:58 PM
Good tip Bill. I bought one of the cheap 6" triangles and I love using it but it was off a few degrees. I used a milling machine to true mine up. This would have been easier.
post #3 of 8 (permalink) Old 01-08-2015, 07:59 AM
First Name: Frank
I have purchased two WoodPecker measuring devices and found them to be just perfect. That being said, I also have some engineering squares and such and they are equally as true.
Tagwatts1 from Utah
Remember to eat your desert first as you may die before your food arrives.
Tagwatts1 is offline
post #4 of 8 (permalink) Old 01-08-2015, 09:45 AM
IC31's Avatar
First Name: Dave W
I wonder if I could put a sanding disc or wheel on my table saw and true up a couple of the cheap triangle squares I own. The miter square is 'true' or can be easily made that way if it's out a bit ........... hmmmmmmmm. Food for thought, mine anyhow
Dave W
Quando omni flunkus, moritati (When all else fails, play dead - R Green)
IC31 is offline
post #5 of 8 (permalink) Old 01-08-2015, 11:18 AM
Table saw? What a good idea. Don't have a disk sander.
post #6 of 8 (permalink) Old 01-08-2015, 11:33 AM
First Name: Barry
Haven't used these but have considered them:
Freud CD010 10" Calibration & Sanding Disk With 5/8" Arbor: Table Saw Calibration Disc Peachtree: Amazon.com: Industrial & Scientific
CMT 299.112.00 10" Table Saw Balance Blade & Sanding Disc Set 5/8" Bore - - Amazon.com
If anyone has used either of these or something similar what was your experience and would you recommend them? I don't have a disk sander but I do have a Dewalt contractor saw.
Barry747 is offline
post #7 of 8 (permalink) Old 01-08-2015, 12:11 PM
IC31's Avatar
First Name: Dave W
Just added the Freud to my AMAZON wish list. Thanks for the links
Dave W
IC31 is offline
post #8 of 8 (permalink) Old 01-08-2015, 01:32 PM
First Name: Mark
I have one on my Triton workcentre, not as convienent as a dedicated disk sander but very handy. Sheets are sticky back not velcro.
I've worn out my sanding disks (Triton no longer make them) and I've found nothing suitable locally, everything's got velcro on the back :-(
Those links Barry gave has given me some leads, ta.
Mark
Mdawson is offline
Accuracy- What do you use for truing, square and setup of tools and jigs? MAFoElffen Tools and Woodworking 18 02-12-2014 09:00 PM
Keeping something square when gluing? ygdrasil54 Starting Off 5 10-30-2006 04:59 PM
Square fence Drick General Routing 5 03-30-2005 02:17 PM
