How much power do you think I need to make one of these? - Router Forums
post #1 of 21 (permalink) Old 01-07-2015, 06:15 PM Thread Starter
Country: Argentina
First Name: Pablo
Default How much power do you think I need to make one of these?
I've been lurking over the internet to gather some info about the construction of (what I think would be best) a table saw hood for fine particle dust collection, more precisely, MDF particles.
So, I came across a lot of homemade "hoods" that would be great for this, for example:
Now, my question is regarding how much powerful would the turbine need to be for that to suck the most of the fine dust particles, instead of them becoming airborne dust really quick.
Artemix is offline
post #2 of 21 (permalink) Old 01-07-2015, 06:23 PM
see if this PDF will help...
File Type: pdf Air Volume at Different Velocities and Duct Sizes.pdf (196.1 KB, 65 views)
File Type: pdf Installing your air handling system.pdf (281.8 KB, 92 views)
post #3 of 21 (permalink) Old 01-07-2015, 06:56 PM Thread Starter
Country: Argentina
First Name: Pablo
I've been reading it, but there is so much information and some knowledge is required to understand what would I need.. honestly I'd rather skip to have to think it for myself and use someone else experience in the matter.
It would take me months to gather enough information and to reach to a valid conclusion of what's best in my particular scenario..
Artemix is offline
post #4 of 21 (permalink) Old 01-07-2015, 07:08 PM
okay...
what do you have for a DC???
what is available to you???
what needs/has DC now...
what will you be adding machines that will want DC....
post #5 of 21 (permalink) Old 01-07-2015, 07:44 PM Thread Starter
Country: Argentina
First Name: Pablo
The main and almost only thing I need DC for is my TS. I use the router very little and the mitter saw (I bought one a week ago, love it) is only used to make a few cuts.
Available here?, nothing really, but I can get one of these:
To use in the system I build.
Artemix is offline
post #6 of 21 (permalink) Old 01-07-2015, 07:50 PM
what's the CFM???
expensive???
post #7 of 21 (permalink) Old 01-07-2015, 08:13 PM
Nickp's Avatar
First Name: Nick
Will you be adding dust collection below the saw blade also...? Or only above the table...?
What is the size of the duct and how long is it in the example you show...?
Is the example what you are going to build...? or is it example only...?
Will you be running a 4" line from the DC to the machine...?
Are you using a zero clearance insert...?
Have you looked at the specs of the "Shark Guard"...? or Excalibur...?
Do a quick search "building the overarm blade guard and dust collector pdf"
Try this PDF http://www.woodcentral.com/bparticles/blade_guard.pdf
Nick
Nick
Nickp is offline
post #8 of 21 (permalink) Old 01-07-2015, 08:19 PM
Nickp's Avatar
First Name: Nick
Good literature, Stick...
Just browsed through the PDF's you suggested...lots of good info...
Very useful to me as I need to add DC to the Darra James in the cabinet under the blade...I'll be reading them more carefully tomorrow at work instead of sleeping :-)
I especially liked the Ducting PDF that talks about CFM's required and sizes of hoses for chips...
Thanks...Nick
Nick
Nickp is offline
post #9 of 21 (permalink) Old 01-07-2015, 08:23 PM
Thanks...Nick
sleeping???
you guys hiring???
post #10 of 21 (permalink) Old 01-07-2015, 08:27 PM
wormil's Avatar
I don't have an overarm but just setting the 4" hose of my Delta 650 cfm dc about 6- 8" from the blade captures most everything but a few of the larger pieces. With a shroud I'm confident it would be more than adequate for your purposes. Hope that helps.
- sent via Tapatalk
||°° I don’t care how it is made ... teeth or a machine, it is the final product that counts. – Tage Frid °°||
wormil is offline
peak hp vs. real hp danapointed New Member Introductions 15 05-10-2017 03:33 PM
How to Make a Simple Clock Using Box Joints learnexperience Tools and Woodworking 2 08-15-2011 09:21 AM
How to Make a Pencil Box learnexperience Tools and Woodworking 2 08-09-2011 11:45 PM
How To Make a Box with a Box Joint learnexperience General Routing 7 08-07-2011 07:07 AM
How to Make a Box learnexperience Tools and Woodworking 0 08-04-2011 10:30 AM
