Flooring a source of hardwood? - Router Forums
post #1 of 14 (permalink) Old 01-09-2015, 07:54 PM Thread Starter
First Name: Paul
Default Flooring a source of hardwood?
I was recently gifted a King portable thickness planer KC-426C (portable at 67lb without the stand is questionable). I have some Acacia hardwood flooring left over from when I did my house. My question is whether it would be suitable for small projects (specifically ornament boxes) where I would need as thin as 3/8" and possibly thinner. Also whether there is anything I need to be aware of considering its hardness (Janka 1750).
psc501 is offline
post #2 of 14 (permalink) Old 01-09-2015, 09:00 PM
go for it...
beautiful wood and wood is wood....
is the flooring prefinished???
can you resaw the wood before dressing it w/ the plane???
save da plane!!! save da plane!!!
at 1750 your Acacia isn't all "that" hard but it is respectable...
is this what you have???
Black Wattle (Acacia mearnsii)
Common Name(s): Black Wattle
Scientific Name: Acacia mearnsii
Distribution: Native to Australia; introduced to many regions worldwide
Tree Size: 20-65 ft (6-20 m) tall, 1-1.6 ft (.3-.5 m) trunk diameter
Average Dried Weight: 46 lbs/ft3 (730 kg/m3)
Specific Gravity (Basic, 12% MC): .59, .73
Janka Hardness: 1,710 lbf (7,590 N)
Modulus of Rupture: 17,660 lbf/in2 (121.8 MPa)
Elastic Modulus: 2,117,000 lbf/in2 (14.60 GPa)
Crushing Strength: 8,960 lbf/in2 (61.8 MPa)
Shrinkage: Radial: 3.1%, Tangential: 7.0%, Volumetric: 10.2%, T/R Ratio: 2.3
Color/Appearance: Heartwood is pink to light brown. Slightly lighter sapwood isn’t always sharply demarcated from heartwood.
Grain/Texture: Grain is interlocked, with a uniform medium texture and decent natural luster.
Endgrain: Diffuse-porous; solitary and radial multiples; medium to large pores in no specific arrangement, few; mineral/gum deposits occasionally present; parenchyma vasicentric, confluent; medium to wide rays, spacing normal.
Rot Resistance: Rated as non-durable; poor insect resistance.
Workability: No data available.
Odor: No characteristic odor.
Allergies/Toxicity: There have been no adverse health effects associated with Black Wattle. See the articles Wood Allergies and Toxicity and Wood Dust Safety for more information.
Common Uses: Flooring, and tannins (harvested from bark).
Comments: Black Wattle has been introduced to many different parts of the world beside its native Australia. It was initially used in the production of tannins, (its bark can contain up to 40-50% tannin), but the species has subsequently been labeled an invasive species in many locales, displacing native vegetation.
Related Species:
Australian Blackwood (Acacia melanoxylon)
Gidgee (Acacia cambagei)
Koa (Acacia koa)
Mangium (Acacia mangium)
Monkeythorn (Acacia galpinii)
Raspberry Jam (Acacia acuminata)
post #3 of 14 (permalink) Old 01-09-2015, 10:52 PM
First Name: Al
If it's never been nailed I would say plane away
al m is offline
post #4 of 14 (permalink) Old 01-10-2015, 06:28 AM
Contributor of the Month
Default Hardwood Flooring as a Wood Source
Sure, why not? I've been using some Canadian Red Oak left over from my flooring project. It's prefinished so I use a 60 grit or coarser sandpaper to remove the finish to save the cutting tools. I just figure it's possible that I may have to replace a floor board in the future but not probable. If you got a lot of leftovers use some and save some.
JIMMIEM is offline
post #5 of 14 (permalink) Old 01-10-2015, 08:01 AM
First Name: Richard
I purchased finished hickory flooring for my wife's hutch. I used it to make the doors and the top. I purchased seconds for the character of the wood.
bluewood is offline
post #6 of 14 (permalink) Old 01-10-2015, 08:18 AM
tvman44's Avatar
First Name: Bob
As you already know rough on blades.
Papa Bob
Using a couple of old Craftsman routers & a Bosch 1617EVSPK & a Dewalt DWP611PK Routers in SW Louisiana.
tvman44 is offline
post #7 of 14 (permalink) Old 01-10-2015, 10:45 AM
GregLittleWoodworks's Avatar
First Name: Greg
I've used left over flooring for several projects and did find a number of very nice lookin grain pieces that were awesome...These were from oak flooring and also from teak flooring.
I used some 40 grit paper on my drum sander to remove the finish and then ran it through my planer to flatten out the grooves that were on the bottom of the flooring.
“Each step of every Wood Art project I design and build is considered my masterpiece… because I want the finished product to reflect the quality and creativeness of my work. I study each piece to get ideas and details that will evolve in my future creations.
GregLittleWoodworks is offline
post #8 of 14 (permalink) Old 01-10-2015, 10:58 AM
kywoodchopper's Avatar
First Name: malcolm
It depends. If the flooring is already has a finish on it you may have a problem. I have found the finish to be aluminum oxide which can't be planed or sanded off. After 5-seconds using 60 grit paper the sander quit removing finish. The planer quit removing wood after several feet is planed off. If the flooring came with a finish you can use the bandsaw or table saw to slice off the finish. Malcolm / Kentucky USA
kywoodchopper is offline
post #9 of 14 (permalink) Old 01-10-2015, 11:45 AM
Good advice Malcolm.
Herb Stoops is online now
post #10 of 14 (permalink) Old 01-10-2015, 09:42 PM
JOAT's Avatar
First Name: Theo
Nope. Do NOT use that wood. Completely useless. Just package it up an send it to me, and I will properly dispose of it. You're welcome.
JOAT is offline
Oak Hardwood Flooring to Make Cabinets Jetski New Member Introductions 13 07-07-2014 07:52 AM
hardwood flooring Houston loreanice DIY and Renovation 6 04-24-2013 02:39 PM
Hardwood flooring for router table top sofasurfer Table-mounted Routing 5 01-13-2010 01:51 PM
5 Tips When Choosing Hardwood Flooring John_smith Project Plans and How To 0 10-17-2008 06:19 AM
