Pipe Clamps - Router Forums
 3Likes
post #1 of 16 (permalink) Old 01-11-2015, 03:47 PM Thread Starter
MT Stringer's Avatar
Default Pipe Clamps
I have an assortment of 1/2 inch diameter pipe clamps. I use them a lot for all sorts of clamping situations.
Recently, I got to thinking about how to maximize what I have so they can be used in more situations.
So, I started looking around for a pipe threader and asked questions on other websites. Someone mentioned using conduit couplings instead of regular pipe couplings. Hmmm...
After more discussion and some old fashioned research (I went to the store), I confirmed the threads are compatible. The main reason for using a rigid steel conduit coupling is it is thinner. That will work for me.
I bought a 1/2 dozen of the couplings at $1.31 ea. Now I have more options for the lengths needed for clamping situations as they arise. The thing to do is use you shorter piece on the end with the crank handle. Makes it easy to take advantage of the longer piece.
I still want to find a threader...maybe ebay...someday.
Here's a tip. If you need more pipe for your clamps, buy a 10 foot piece at the big box store and have them cut it and thread the pieces. I checked, and you can too. Ten foot 1/2 inch black pipe is $10.88 at my local store. Sitting in the rack next to it is a four foot piece marked $9.88 ...well, duh. That is a no brainer. Had I been more attentive over the years, I think I could have saved well over $50 just by buying a long stick and having them cut it and thread the ends.
1 ten foot stick = 2 @36, 2 @ 24 inches. Or...
2 @ 48, 1 @ 24. The 24 and one 48 would be free! :-)
Here are some pics of my clamps in action. I have some 18 inchers, 24, 36, 48, and 60's. With the couplings, I can make almost any length I need.
Name:	2013-10-16 20.36.37.jpg
Name:	2014-06-16 21.15.24.jpg
Name:	2014-07-28 19.56.13.jpg
Name:	2014-12-01 19.14.02.jpg
Name:	2014-12-02 14.00.10.jpg
Name:	2014-12-02 14.00.20.jpg
Name:	2015-01-05 18.28.12.jpg
Name:	2015-01-05 18.21.46.jpg
Name:	2015-01-05 18.22.05.jpg
Name:	2015-01-05 18.30.20.jpg
MT Stringer is offline
post #2 of 16 (permalink) Old 01-11-2015, 03:56 PM
Good tip about the conduit coupling. I bought my son a threading set off eBay and it was$200 Mike. You would be better off to just pay to have it done.
post #3 of 16 (permalink) Old 01-11-2015, 06:22 PM
Mike, do you buy the tubing already threaded?
I bought some pipe to make clamps and nearly killed myself trying run the dies on the pipe...
Sydney, Australia
jw2170 is offline
post #4 of 16 (permalink) Old 01-11-2015, 06:50 PM
First Name: Al
Like all your advice,good,practical advice we can all benifit from.i have used the cast unions and they have got in the way and marked my work.i will be looking for these
Thanks Mike
al m is offline
post #5 of 16 (permalink) Old 01-11-2015, 07:00 PM
James; the electrical ridgid conduit and/or black iron both com with both ends threaded. It's only when you start breaking it down that the unthreaded ends show up.
Mike's description didn't cover the point of exactly what your maximum working length will be .
A 24" piece of pipe will probably only give you 18" or less of clamping space, after you deduct the thread at one end (plus a bit extra for the screw mechanism, plus a bunch of lost room at the other end for the sliding portion.
So in reality, a 10' length might only yield a pair of 5 footers...perfect for 4' panels.
Those broken down into 2X30" per 5' length should cover the 2' gable requirement...but I'd be a lot more comfortable with 36" clamps.
Bottom line, check your actual clamps for their individual space needs!
DaninVan is offline
post #6 of 16 (permalink) Old 01-11-2015, 08:17 PM Thread Starter
I have several pieces that have been cut in half so one end doesn't have threads. That's one reason for looking for a threader.
@James, your comment isn't the first one I have heard about threading with a hand held threader. I think if I need more pipe, I will get it cut and threaded at the store...even if it is a small charge. Otherwise, I might put out a shout to my friends on the fishing forum I am on. Many of them are in my area, so I might get lucky. :-)
Those shorter pieces are used for gluing up cutting boards, drawer stock and assembly operations that are not very large.
I know the black pipe is cheaper, but I don't like it. I guess I could buy a cover for a shower curtain and cut it up in pieces so it would cover the glue joints. <-Tip
post #7 of 16 (permalink) Old 01-11-2015, 11:18 PM
I've had good luck threading the occasional pipe with this: 1/2 in. - 1 in. Ratcheting Pipe Threader Set
Not professional quality, but does the job adequately- even ran a leak proof natural gas line extension using this.
jdonhowe is offline
post #8 of 16 (permalink) Old 01-11-2015, 11:43 PM
DaninVan is offline
post #9 of 16 (permalink) Old 01-12-2015, 04:29 AM
First Name: Ken
Looks like the regular price on that is $29.99, but Harbor Freight frequently has 20% off coupons available. That would make the threader set a real bargain.
kklowell is offline
post #10 of 16 (permalink) Old 01-12-2015, 07:30 AM
Country: Brazil
First Name: sid
Very handy hint!
Sid
ksidwy is offline
Pads for my pipe clamps. papasombre Jigs and Fixtures 5 12-05-2014 11:28 PM
Pittsburgh 3/4 Inch Heavy Duty Pipe Clamps Gaia Tools and Woodworking 9 03-04-2012 04:01 AM
Availibility Of 3/4 Inch Pipe Clamps In The UK Gaia Tools and Woodworking 0 02-28-2012 04:55 AM
pipe clamps mah Tools and Woodworking 44 02-17-2012 08:08 AM
PVC Pipe Holes morbious Tools and Woodworking 3 02-15-2008 04:50 PM
