Bosch 3727 DVS Sander Replacement Pad - Router Forums
post #1 of 5 (permalink) Old 01-21-2015, 01:43 AM Thread Starter
First Name: lee
Default Bosch 3727 DVS Sander Replacement Pad
I am trying to figure out the correct sanding pad replacement for my Bosch 3727DVS sander. My local Home depot does not stock them so I have to mail order. The pad I think I need is a rs6045. The rs6041 pad is a hard rubber pad for polishing. I have also seen a rs6044 pad. I don’t know if it is a misprint or another pad. Which pad do you guys use for sanding?
coxhaus is offline
post #2 of 5 (permalink) Old 01-21-2015, 02:20 AM
Semipro's Avatar
First Name: John_*
Semipro is online now
post #3 of 5 (permalink) Old 01-21-2015, 02:26 AM
Hey, Lee;
isn't there a p/n on on your existing pad?
John's link has three pads listed, one of them must be the same as your old one(?).
Logically, the hard pad would be more inclined to take down the high spots, leaving the lower soft material alone, until of course (oops sorry, no pun intended) everything stands at the same level. The extra soft would do the exact opposite, conforming itself to all exposed surface....but wearing away the softer grain faster.
DaninVan is online now
post #4 of 5 (permalink) Old 01-21-2015, 03:02 AM Thread Starter
First Name: lee
Turns out the pads were superseded maybe when the 3727 DEVS sander came out. I donít have the old pad any more. I thought this would be a an easy thing to replace.
The diagram is the DEVS version not the DVS version which I have of the sander.
coxhaus is offline
post #5 of 5 (permalink) Old 01-21-2015, 03:16 AM
Originally Posted by coxhaus View Post
I am trying to figure out the correct sanding pad replacement for my Bosch 3727DVS sander. My local Home depot does not stock them so I have to mail order. The pad I think I need is a rs6045. The rs6041 pad is a hard rubber pad for polishing. I have also seen a rs6044 pad. I donít know if it is a misprint or another pad. Which pad do you guys use for sanding?
take a sure thing short cut and call customer service...
1-877-BOSCH99
(1-877-267-2499)
Replacement bearings for Bosch 1617EVS mickelsen General Routing 2 04-29-2011 07:28 AM
Bosch router bearing replacement tbarbour General Routing 5 03-03-2011 05:46 PM
Bosch Colt replacement collet Tripp1 General Routing 1 03-26-2010 06:52 PM
Replacement Wrenches for Bosch 1617 Needed dbishopbliss General Routing 8 07-25-2009 08:50 PM
Bosch 3107 DVS 5" Random Orbital Sander rstermer Tool Reviews 5 06-15-2009 09:56 PM
