King Canada 3.25 hp router - comments? - Page 4 - Router Forums
 3Likes
post #31 of 40 (permalink) Old 01-02-2014, 04:59 PM
First Name: Doug
Default King Plunge router comment about removing springs
Can you tell me how you removed the springs? See you comment below regarding the King 3 1/4 plunge router
When you plunge it up and down the springs are very noisy and sounds terrible. So I was a little hesitant at first. So I brought it home and
removed the springs,very easy to remove, and I use it table mounted.
windon is offline
post #32 of 40 (permalink) Old 01-02-2014, 08:29 PM
"King is made in Canada somewhere just outside Montreal. They have been making tools since 1920 or so that I know of."
?!...Is it possible the name has been uh, 'liberated' ?
"In 1983 King took over its name and started developing a complete program, selling machinery in collaboration with their partner factories."
Power Tools, Woodworking and Metalworking Machines by King Canada
I'm pretty sure the King cabinet saws that I looked into were built in Taiwan, but that certainly doesn't suggest that there's anything wrong with their products.
The company bio seems to indicate a number of manufacturing sources.
DaninVan is offline
post #33 of 40 (permalink) Old 01-03-2014, 12:11 AM
I bought a King 16" planer years ago. It's been a very good machine to me. A few years later a cousin bought a Delat, one that I don't see in their lineup any more. It was for all practical purposes identical to mine. Jet also has one that is identical, the JWP-160S. Their used to be an equipment company named Star and theirs was also identical. There may be others. That tells me that they are all likely made in Taiwan. Makita and Hitachi aren't any better in some cases. I have a 1900B Makita 3 1/8" power planer. When I was looking for blades for it on ebay I found out that Hitachi also uses the same blades on their model 1900B and it was identical in every way but colour. One seller on ebay showed pictures and names of all the planers that used those blades and there were at least 2 more with identical housings and about 18 more with different housings which may or may not have been made by the same company. You really can't say for sure who made a tool no matter who's name is on it.
post #34 of 40 (permalink) Old 06-15-2020, 09:32 PM
Bought a new King Canada router. Tried to attach the inlay template guide that came with it. There was NO WAY of fastening it. Sent King Canada in Quebec and was told they checked and found I was right and said thanks for bringing it to our attention and GO OUT AND BUY SOME SCREWS AND WASHERS and fix it myself. Sent another email saying THEY NEED TO SEND a fix. Then they tried the old need to see your proof of purchase trick. THEY JUST FOUND THE PROBLEM BECAUSE I FOUND THE PROBLEM...how did I know that if I didn't buy one?? STAY AWAY FROM THEIR JUNK and you will not have to deal with them.
MTWEAVER is offline
post #35 of 40 (permalink) Old 06-16-2020, 12:04 AM
The biggest problem I see with King Canada tools is that the customer is their quality control. I bought a 6" x 108" vertical belt sander and the table wasn't square to the belt. They grudgingly replaced the brackets that held it. I bought a 16" open ended drum sander and they had to replace the top cover with one that I could attach a vac hose to. They did do that without any issues. Then I bought a 12" disc sander it it had a bad wobble to it. After 3 replacement disc plates I gave it back. That wasn't all on King, the repair shop I took it to didn't check the motor shaft and I finally did and it was out of round. Never the less I think I'm done with King.
Herb Stoops likes this.
post #36 of 40 (permalink) Old 06-16-2020, 12:12 AM
Is this the one? Sure looks familiar to some other brand I have seen.
http://files.kingcanada.com/catalog/...resxm/8367.jpg
Herb Stoops is offline
post #37 of 40 (permalink) Old 06-16-2020, 12:16 AM
is King Canada your version of our Harbor Freight???
post #38 of 40 (permalink) Old 06-16-2020, 12:30 AM
Go Harbor Freight!!!
jj777746 likes this.
post #39 of 40 (permalink) Old 06-16-2020, 02:16 AM
I feel better now that you took the bait..
stay tuned - more chumming to follow...
post #40 of 40 (permalink) Old 06-16-2020, 11:07 AM
No. I would say it's on a par with the cheapest models of Delta. At least in their stationary power tools. In fact they may be made in the same factory. As for the powered hand tools I can't say. The only small King tool I own is an air roofing nailer. It worked okay on the one roof that I needed it for. The flap that holds the coil in did get broken off though because it was balky and the guy using it applied force instead of brains to close it.
Stick486 likes this.
  LinkBacks (?)
LinkBack to this Thread: https://www.routerforums.com/tools-woodworking/549-king-canada-3-25-hp-router-comments.html
Posted By For Type Date
[Home] Costco - $20 off King Canada Table Saw w/ stand - $139.99 - RedFlagDeals.com Forums This thread Refback 05-20-2010 12:45 PM
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
Need Help removing springs from King Canada plinge router chuckwpg Table-mounted Routing 3 04-16-2007 04:58 PM
