Where to buy pipe for clamps? - Router Forums
post #1 of 14 (permalink) Old 01-25-2015, 05:45 PM Thread Starter
First Name: Matt
Default Where to buy pipe for clamps?
I've been looking for pipe clamps on Craigslist forever with no luck. So now I'm thinking I'm going to to need to buy them new. Anyone know where to get piping at low cost? Thanks for your help!
Matt
mlrlangley24 is offline
post #2 of 14 (permalink) Old 01-25-2015, 05:54 PM
Matt
find a wholesaler... plumbing or electrical....
buy their damaged sticks of pipe at near recycle prices...
go to a recycle yard... cull what you need and buy theirs...
post #3 of 14 (permalink) Old 01-25-2015, 06:10 PM
MT Stringer's Avatar
If all else fails, go to either HD or Lowes. Buy the ten foot stick and ask them to cut and thread in whatever lengths you need.
$10 bucks for 10 foot stick of 1/2 inch black pipe is pretty cheap. 3/4" is a little more.
Just in case you aren't aware, you do need them threaded on one end at least - both if you plan to use couplings.
MT Stringer is offline
post #4 of 14 (permalink) Old 01-25-2015, 06:11 PM
oji
oji's Avatar
First Name: Stephen
What MT said. That was going to be my suggestion. Do Lowes if you are a veteran and get the 10% discount.
oji is offline
post #5 of 14 (permalink) Old 01-25-2015, 06:21 PM Thread Starter
First Name: Matt
Thanks. I think I'll try Lowes. I have a gift card and I'm military
post #6 of 14 (permalink) Old 01-25-2015, 06:31 PM
Pick up a few pipe couplings out of the electrical department. The couplings for rigid steel conduit are thinner than the pipe couplings. See pic below.
Note: I have been going through a similar situation as you only I just wanted more to go with what I have.
Name:	2015-01-05 18.28.12.jpg
Name:	2015-01-05 18.21.46.jpg
Name:	2015-01-05 18.30.20.jpg
post #7 of 14 (permalink) Old 01-25-2015, 07:16 PM
First Name: Phillip
HD will thread the pipe for you for free. The pipe is pretty inexpensive (galvanized is less expensive than black, but they both work).
I even wanted a couple pieces cut then threaded and they did it for me on the spot!
To change the world, change your mind.
phillipdanbury is offline
post #8 of 14 (permalink) Old 01-25-2015, 07:53 PM
First Name: Ken
Home Depot also gives a 10% discount for active military and veterans.
kklowell is offline
post #9 of 14 (permalink) Old 01-25-2015, 07:59 PM
If you can find an industrial building being torn down you can probably get all you want for a case of beer.
post #10 of 14 (permalink) Old 01-26-2015, 01:05 AM
First Name: lee
I just went to Home Depot and bought a 10 foot ¾ inch galvanized pipe. I had to glue a folding door 78 inches long so I needed an extension for my pipe clamp. I had the Home Depot guy cut an extension off a 10 foot pipe for my job. I then had him cut the left over in half and thread both ends so I could make 2 more pipe clamps. I had my eye on the Bessey H-seires pipe clamps with the feet on them. I kind of like the shorter pipe clamps, they seem handy. It makes it so easy to lengthen the pipe using the electrical connectors which I found out about on this forum. Just make sure you have your pipe threaded on both ends.
coxhaus is offline
PVC Pipe Holes morbious Tools and Woodworking 3 02-15-2008 04:50 PM
