Rikon Fence Upgrade - Router Forums
post #1 of 5 (permalink) Old 01-28-2015, 11:40 PM Thread Starter
First Name: lee
Default Rikon Fence Upgrade
I have a green Rikon 10 inch bandsaw which I like. The problem I have run into is the fence is not very good. Does anybody know of a replacement fence for this small bandsaw? Did I say I really like this little bandsaw. It fits so nice in my small shop and does what I need basically. I just need a better fence. I want to start cutting tenons on the bandsaw but I need a fence I donít have to clamp every time I want to use it.
coxhaus is offline
post #2 of 5 (permalink) Old 01-29-2015, 02:19 AM
old55's Avatar
First Name: Ross
Lee I can't help with your inquiry but I'm sure someone will be able to give you advice.
Ross,
ĎMembers are requested to add a first name in their profile as we are a very friendly bunch here'.
old55 is offline
post #3 of 5 (permalink) Old 01-29-2015, 10:19 AM
Lee, I have the same saw and also hate the fence. I now use the Carter Magfence II with the UHMW sacrificial fence-- it works great. Check it out:
https://www.youtube.com/watch?v=ilAWl6NSZj4
JimBroyles is offline
post #4 of 5 (permalink) Old 01-29-2015, 11:04 AM
I have a Kreg fence that I think will work on that size as well. I'd contact the maker. A lot of people seem to like that magnetic fence, mine adds a rail to the front edge of the table.
DesertRatTom is online now
post #5 of 5 (permalink) Old 01-29-2015, 01:14 PM Thread Starter
First Name: lee
I went to woodcraft and they had both of the fences mentioned above. The mag fence seems like it will take quite a bit of adjusting to cut tenons but it would probably work. It would be better than having to clamp my fence every time.
I like the way the Kreg fence works as it works parallel to the blade once setup. I think it would be faster than the mag fence. It is a little big for this small bandsaw though. I think with a piece of angle iron I could make it work. The screws out of the cast iron top on the Rikon 10 inch point down instead of horizontal. The side of the Rikon top is a little thin to drill into for the size of the bolts in the Kreg fence. I think it was made for a large top.
coxhaus is offline
Laguna TSS. MAFoElffen Tool Reviews 12 08-12-2017 10:30 AM
Question Upgrade Fence or Router ronheb454 Table-mounted Routing 9 07-30-2013 01:15 AM
Kreg Precision router fence #PRS1010 TwoSkies57 Table-mounted Routing 2 06-29-2013 12:45 PM
upgrade table saw fence fjharmon New Member Introductions 10 11-06-2012 04:19 AM
