Broken Screw Repair - Router Forums
post #1 of 15 (permalink) Old 01-31-2015, 01:01 PM Thread Starter
MT Stringer's Avatar
Default Broken Screw Repair
Dang it! I broke a screw!
Actually, this happen last year but I thought I would share how I resolved the issue.
I was building cabinets using hard maple. Even though I had predrilled a pilot hole in the door frame, the screw broke when I was screwing it in. Either the pilot hole was too small or the screw was too big. The idea of having to make a new door made me sick at my stomach.
After taking a break and thinking about my dilemma, I devised a plan to repair the broken screw. Note that this may or may not work in other situations, but it worked perfectly for me in this instance. Note: The screw broke flush with the wood. There wasn't anything that I could grip with pliers.
Step 1 - Remove the broken part of the screw
After removing the other screw and the hinge, I used a plug cutter to cut around the area containing the broken screw threads. Using a hand held drill, that was actually easy to do. And wouldn't you know it, I broke a second one while removing the hinges! Now that I think about it, maybe the cordless drill had too much torque and simply snapped it off.
Step 2 - Plug the hole
Using the next larger size plug cutter, I cut a few plugs from the same wood the doors were built from (hard maple). After that, it was a simple matter of gluing the plug into the hole(s).
Step 3 - Finish the repair
Once the glue was dry, I taped off the surrounding area and sanded the plug flush with the frame.
Step 4 - Reinstall door hinge
I used a slightly larger pilot drill bit and hand screwed the screws into the hinge. Not surprisingly, all went well. There is no evidence of any repair because the hinge covers the repaired area.
Hope you find this info useful. File it for future reference. You may need it some day.
Name:	2014-03-09 20.50.52.jpg
Name:	2014-03-10 13.56.01.jpg
Name:	2014-03-10 13.58.28.jpg
Name:	2014-03-10 14.00.02.jpg
Name:	2014-03-10 14.09.27.jpg
MT Stringer is online now
post #2 of 15 (permalink) Old 01-31-2015, 06:25 PM
TwoSkies57's Avatar
He'sssssssssss safeeeeeeeeeeeeeeeeeeee!!!!!
nice!
Skipper the Penguin
TwoSkies57 is offline
post #3 of 15 (permalink) Old 01-31-2015, 08:48 PM
old55's Avatar
First Name: Ross
Nice one.
Ross,
old55 is online now
post #4 of 15 (permalink) Old 01-31-2015, 08:58 PM
Ghidrah's Avatar
First Name: Ronald
Mike sometimes its the screw, quite often even with square head screws if the predrilled hole is too small the bit tends to torque out of the screw head with little encouragement. Or I've had a few screws twist out of straight (warp). With maple and oak I adopted the sacrificial pre-screw. Screw down, back out, screw down deeper then back out. I wreck a lot of sacrificial screws but I always have something to grab with the vise grip.
Ghidrah is offline
post #5 of 15 (permalink) Old 02-01-2015, 12:31 AM
I usually scrape a candle or piece of paraffin wax over the threads before driving them into hardwood or old D. Fir. You won't believe the difference.
DaninVan is offline
post #6 of 15 (permalink) Old 02-01-2015, 12:51 AM
Good save, Mike...
Sydney, Australia
jw2170 is online now
post #7 of 15 (permalink) Old 02-01-2015, 01:34 AM
Semipro's Avatar
First Name: John_*
I buy the hinges with dowel no screwing,drill 3 holes hammer in the first time
http://assets.rockler.com/media/cata...77-02-1000.jpg
Compact 33 Face Frame Hinge 110 Degree/Dowel (#33.3630) by Blum | Shop & Save at CabinetParts.com
Semipro is online now
post #8 of 15 (permalink) Old 02-01-2015, 07:55 AM
First Name: Dennis
Good save Mike. I always keep a little bees wax or toilet bowl wax around whenever I am using any small screws that could possibly break off and be a problem. Small hinge screws and the like I run in by hand. Who knows where the screws come from and what quality they are.
Dennis
Tough as nails and nearly as smart
Good tools don't cost- they pay!
64 ford is offline
post #9 of 15 (permalink) Old 02-01-2015, 08:58 AM
chessnut2's Avatar
Mike........Nice save, and as always, nice pictures. And good ideas from everyone. A longer sacrificial screw and wax have become part of my routine. Jim
chessnut2 is offline
post #10 of 15 (permalink) Old 02-01-2015, 09:24 AM
Guitfiddle's Avatar
First Name: Wes
I use plain Ivory bar soap for screw lube - slippery but not sticky.
Guitfiddle is offline
JessEm Master R Lift Excel Repair Model #02201 TRN_Diesel Tools and Woodworking 10 06-07-2018 11:48 PM
Got a screw loose! idarwin Table-mounted Routing 4 09-07-2014 07:36 PM
A simple fix for the screw gone too deep xplorx4 Show N' Tell 2 03-05-2010 12:48 PM
How To Destroy Screw Heads cabinetman Lobby 4 06-09-2007 06:03 AM
