Makita 2040 Planer Cutterhead Bearings - Router Forums
post #1 of 3 (permalink) Old 02-11-2015, 10:03 AM Thread Starter
DonkeyHody's Avatar
First Name: Andy
Default Makita 2040 Planer Cutterhead Bearings
I'm trying to replace the cutterhead bearings on my Makita 2040 planer. The sealed bearings seem to be pressed into the heavy aluminum head casting (Main Frame) with no obvious way to remove them. Has anyone ever replaced these bearings and have experience to offer? Here's the parts diagram:
Makita 2040 Parts List and Diagram : eReplacementParts.com
Thanks.
DonkeyHody is offline
post #2 of 3 (permalink) Old 02-11-2015, 02:12 PM
I couldn't tell from the diagram but I'm guessing that you can use the cutter head to drive one bearing out, possibly both once you get one out and put it back in and drive it the other way. Or use a long rod. You have to be careful not to mushroom the end of the shaft. If one end has a bolt in it I would tap on it.
post #3 of 3 (permalink) Old 02-11-2015, 06:22 PM Thread Starter
DonkeyHody's Avatar
First Name: Andy
Figured it out! Charles was right, the entire drum just came out the end of the head. Then I was able to pull the bearings off the shaft. Thanks.
Questions about replacing bearings in a Makita 3612BR Grub General Routing 8 12-22-2014 07:03 PM
delta 22-580 planer bearings woodworkher Tools and Woodworking 3 12-26-2012 01:08 PM
