legacy 600exl ornamental mill how to mount dw 3hp plunge router - Router Forums
 2Likes
post #1 of 16 (permalink) Old 02-12-2015, 05:18 PM Thread Starter
First Name: dave
Default legacy 600exl ornamental mill how to mount dw 3hp plunge router
would anyone know what the original price of the legacy 600exl was, was just wondering.
davefrommd is offline
post #2 of 16 (permalink) Old 02-12-2015, 07:23 PM Thread Starter
First Name: dave
i have a legacy 600exl and would like to mount a dewalt 3hp plunge router, i understand they are designed to use a pc router, does anyone have a legacy with a dw router mounted, any help or suggestions would be greatly appreciated. it looks like i will have to center it and drill 3 holes, just trying to figure out the best way. thanks
post #3 of 16 (permalink) Old 02-12-2015, 07:37 PM
old55's Avatar
First Name: Ross
Dave can't help you with your inquiry but I'm sure someone will be able to help.
Ross,
old55 is offline
post #4 of 16 (permalink) Old 02-12-2015, 11:16 PM Thread Starter
First Name: dave
thank you very much.
post #5 of 16 (permalink) Old 02-13-2015, 02:56 AM
Phil P's Avatar
First Name: Phil
Hi Dave
I don't know that model, but there is an importer selling the Legacy over here in the UK and as we are almost exclusively on plunge routers here, with very few fixed base models on the market, I'd have though that there would be a way. I know a guy who has a Legacy down in London, but his is a relatively basic model with a flat router base plate so the router with it's base just clamps/screws to that. It looks a bit like this:
so mounting a plunger would be easy. Some plunge routers, like the DW625, can be removed from the sprung base and vlamped around the collar at the bottom of the body (the DW625 also has two machine screw holes for mounting to shop-made jigs/machinery).
BTW what does your Legacy look like (can't find it on the Legacy site)?
Have you tried contacting Legacy themselves?
Regards
Phil
Edit: Correction. I found the reference to the (former?) UK importer, who are called Woodworkers Workshop. Unfortunately they no longer list the Legacy on their web site
Phil P is offline
post #6 of 16 (permalink) Old 02-13-2015, 11:47 AM Thread Starter
First Name: dave
here is the legacy 600exl ornamental mill, i know how it mounts, if i need to drill any holes i want to be certain that the router is perfectly centered. the 4 hole mount is for a porter cable router and i have a dewalt with a 3 screw mount.
post #7 of 16 (permalink) Old 02-13-2015, 12:11 PM
Phil P's Avatar
First Name: Phil
Hi Dave
Sorry the last link went a bit askew, but basically yours is the same type of Legacy I was referring to. My colleague down in London has his DW621 mounted straight onto the silver rectangular plate with the cutter centred over the hole. He needed to drill a couple of holes in the flat plate of the Legacy to do this. Whilst the DW625 has a different base there are a couple of holes you could use.
Regards
Phil
Phil P is offline
post #8 of 16 (permalink) Old 02-13-2015, 01:21 PM
kp91's Avatar
First Name: Doug
Dave,
That is a great looking old Legacy, the forerunner to the 900.
I can't tell from your picture, but have the 'rulers' been glued to the carriage yet? If not, all you have to be is close, and you can glue the rulers to align.
Fortunately, my legacy was pre-drilled for my router. If I was in your situation, I would do the following.
Use your router and circle jig to cut a circle that fits snugly in the mounting plate hole.
Bore the pilot hole you used to cut the circle to 1/2 inch, and put a 1/2 inch straight cutter in your router.
Use the circle to center your router in the hole, and transfer the mounting holes to the plate.
This should have everything in perfect alignment.
Hope it works, it's a great tool to play with.
Dont forget to look at Magnate.net for all of the legacy ornamental mill bits you need. They sell direct from their website and from Ebay.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #9 of 16 (permalink) Old 02-17-2015, 10:29 PM Thread Starter
First Name: dave
thanks very much for the help and suggestions, i am almost finished with my tool stand i am making for my legacy, then i will mount my router.
post #10 of 16 (permalink) Old 03-12-2015, 06:12 PM Thread Starter
First Name: dave
fabricated tool stand, working on "Y" axis using acme 5/8-8 tpi threaded rod, may use 5/8 bearing, or bronse bushing, and delrin 5/8-8 threaded block
jj777746 likes this.
legacy ornamental mill Robert Kent New Member Introductions 0 12-04-2011 07:18 PM
