Tuning a framing square - Router Forums
post #1 of 6 (permalink) Old 02-13-2015, 09:17 AM Thread Starter
PhilBa's Avatar
First Name: phil
Default Tuning a framing square
This is in response to a question in another thread. I didn't see any thread that addressed this so thought to post it separately. There are couple of videos but they really aren't that good.
Framing squares are notorious for being off. I have 2. One was very close but the other was way off. You can tune the square to true by using a machinist's center punch. The kind used for making a mark before drilling a hole.
Get a piece of sheet material with a straight edge. I used 1/4" melamine. It should be sized to at least fit your framing square 2X in one dimension and 1X in the other (for an 18x24 it should be 36x24). The long edge must be dead on straight.
Line up the short side of the square with the straight edge and draw a perpendicular line in the middle of the sheet. Flip the square over and align it with the edge and line you drew. If the line you drew is parallel to the square's edge, you are done. If not, hit the punch on either the inside or outside corner to adjust the square. (Do it some where other than on the sheet material.) If the square is less than 90 deg, punch the inside corner. If greater, punch the outside. Draw a new line and repeat the process as needed. I used the outside edge of the square. The inside and outside edges should be parallel but use which ever you use the most for the best accuracy.
This worked really well for me. I lightly tapped the square that was really close and it took about 5 hits to bring the other one to square. Now, both are spot on.
By the way, if you drop your square, it wouldn't hurt to check it for true.
PhilBa is online now
post #2 of 6 (permalink) Old 02-13-2015, 02:45 PM
wormil's Avatar
I did mine awhile back and it was surprisingly easy, or maybe just beginners luck.
- Rick M, sent via Tapatalk
||°° I don’t care how it is made ... teeth or a machine, it is the final product that counts. – Tage Frid °°||
wormil is offline
post #3 of 6 (permalink) Old 02-13-2015, 09:06 PM
First Name: Katie
Thanks for posting this. I'm going to try it.
Goblu is offline
post #4 of 6 (permalink) Old 02-14-2015, 11:16 AM
This is a great hint. Thanks.
DesertRatTom is online now
post #5 of 6 (permalink) Old 02-14-2015, 01:29 PM
smitty10101's Avatar
First Name: smitty
Send a message via Yahoo to smitty10101
I got a question--- when truing a framing square I've noticed that the inside edge or outside edge can be made square but I've been unable to get both edges of the leg to be square. I'm guessing that somehow the leg varies in width over the length of the leg.
This annoyed me enough that I have squares that I made the outside edge square and others that the inside edge is square. I do have ONE square the is perfectly square on both edges. Anyone run into this and is there a quick fix?
smitty10101 is offline
post #6 of 6 (permalink) Old 02-15-2015, 11:40 PM Thread Starter
PhilBa's Avatar
First Name: phil
I think not unless you can precision mill one edge. Might be easy just to have two.
By the way one of mine is very close but the inside and out side on the other is way off.
Accuracy- What do you use for truing, square and setup of tools and jigs? MAFoElffen Tools and Woodworking 18 02-12-2014 09:00 PM
How Square is your Square? paduke Starting Off 19 12-02-2011 10:34 AM
Keeping something square when gluing? ygdrasil54 Starting Off 5 10-30-2006 04:59 PM
Square fence Drick General Routing 5 03-30-2005 02:17 PM
