What Wood To Use For a Painted Cabinet - Router Forums
 11Likes
post #1 of 27 (permalink) Old 02-13-2015, 12:00 PM Thread Starter
Contributor of the Month
Default What Wood To Use For a Painted Cabinet
I need to build a cabinet for a basement playroom area. It doesn't need to be fine furniture grade. It will placed on the floor in a corner and its purpose will be to hide some mechanicals. It will have a door to access the mechanicals. It will be 24" W X 24" D X 36" H. It will be painted. I would appreciate some suggestions as to what wood to use. I do not want to use MDF or Melamine.
JIMMIEM is offline
post #2 of 27 (permalink) Old 02-13-2015, 12:03 PM
TwoSkies57's Avatar
Popular or Pine/Fir.... easy to get, easy to work, takes paint well and afforadable...
Skipper the Penguin
TwoSkies57 is offline
post #3 of 27 (permalink) Old 02-13-2015, 12:14 PM Thread Starter
Default Wood for Painted Cabinet
Thank You. I like using poplar and recently made some closet shelving with it. Any thoughts on using a paint grade plywood? Wide panel glue-ups aren't my favorite thing to do.
JIMMIEM is offline
post #4 of 27 (permalink) Old 02-13-2015, 12:19 PM
DonkeyHody's Avatar
First Name: Andy
The big box stores will have something they call sandply or paraply. It takes paint nicely. I'd recommend oil based paint, at least for the first coat because waterbase will raise the grain and you'll be sanding to get it smooth again.
DonkeyHody is offline
post #5 of 27 (permalink) Old 02-13-2015, 12:20 PM
paint grade is fine as in Birch w/ poplar for frame work......
Herb Stoops likes this.
post #6 of 27 (permalink) Old 02-13-2015, 12:20 PM
TwoSkies57's Avatar
Ply is fine if thats what you like to use. Or a combination of the two (solid wood & ply) for the construction. Either use a filler on the exposed edges or some trim to cover em up
Skipper the Penguin
post #7 of 27 (permalink) Old 02-13-2015, 01:28 PM
kp91's Avatar
First Name: Doug
Personally, I love poplar. We can get wide boards here pretty cheap.
If you don't want to do glue ups, there are a couple of makers of sanded laminated pine panels out there. They are a great compromise between 'real wood' and plywood or MDF.
They came in real handy for a bookcase project I did for our church in a hurry. I didn't have to glue up any panels.
Shop Edge-Glued Panels & Rounds at Lowes.com!
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #8 of 27 (permalink) Old 02-13-2015, 01:32 PM
Doug; I second that!
DaninVan is online now
post #9 of 27 (permalink) Old 02-13-2015, 02:44 PM
MT Stringer's Avatar
Our Lowes carries panels up to 4, maybe 6 feet in length and up to 24 inches wide. One is paint grade and the other is stainable. That is what I made the last toy box out of.
I like Stick's idea of birch plywood and poplar face frame. Or even the white pine looking wood should work. It is soft though.
I don't have a basement so I gotta ask. Do you have any problems with moisture? I read somewhere they say to put down treated wood on the concrete floor so the moisture wont seep in.
That might be as simple as putting some 2x4 blocks in the corners and middle under the box. You could add a base moulding to the box to hide tha blocks. :-)
Well, heck, Doug already provided a link to those panels. Good job, bud. Bad job Mikey for not reading the post.
MT Stringer is offline
post #10 of 27 (permalink) Old 02-13-2015, 05:48 PM
paduke's Avatar
The only thing I will add -----Durhams wood putty and paint makes us what we aint The stuff is great for blems knots and plywood edges
48394 and Herb Stoops like this.
paduke is offline
Introduction to Wood Species... BobandRick Wood Species 40 03-19-2015 12:03 PM
Reclaiming wood Mike Tools and Woodworking 13 11-18-2012 12:01 PM
Choosing the best wood for outdoor projects Hamlin Wood Species 5 07-21-2009 07:40 PM
A Wood Experience-Contest Woodworkers Source Contests Archive 2 05-14-2009 05:58 PM
