Lubricant - Router Forums
post #1 of 15 (permalink) Old 02-21-2015, 08:36 PM Thread Starter
N'awlins77's Avatar
First Name: Lee
Default Lubricant
As some of you will remember, I bought a vintage Sears Craftsman planer. Well I'm in the middle of rebuilding it. Took it completely apart, cleaned it, sanded and painted. Bought new bearings for head and new knives. After I get some of it back together (head assembly back together.) I'm going to take apart the motor and change the bearing in it.
My question, as I go back together with it, what would be the best lubricant/grease to use on the screw that lifts the table, and the slideways of the machine. I think regular grease or oil would just attract the wood chips.
N'awlins77 is offline
post #2 of 15 (permalink) Old 02-21-2015, 08:44 PM
TwoSkies57's Avatar
Lee.. good stuff!!!
http://www.amazon.com/WD-40-Speciali.../dp/B00CMT9QJ8
Skipper the Penguin
TwoSkies57 is offline
post #3 of 15 (permalink) Old 02-21-2015, 08:45 PM
dry lube w/ PTFE....
I'm partial to TriFlow...
it has never let me down...
Tri-Flow Superior Foam Lubricant :: PTFE Lubricant :: Tri-Flow®
post #4 of 15 (permalink) Old 02-21-2015, 08:46 PM
TwoSkies57's Avatar
Blows the smoke off his barrel.......
Skipper the Penguin
post #5 of 15 (permalink) Old 02-21-2015, 08:51 PM
that plural I'll have you know...
post #6 of 15 (permalink) Old 02-21-2015, 09:25 PM
Nice looking machine Lee. Dry silicone or graphite similar to what Stick suggested. Anything that doesn't go on and dry up will attract dust.
post #7 of 15 (permalink) Old 02-22-2015, 02:39 AM Thread Starter
N'awlins77's Avatar
First Name: Lee
Thanks Bill & Stick! I see my local Auto Zone carries the WD 40 Specialist spray. Sounds just what I was looking for!! I will pick up some later in the morning!
post #8 of 15 (permalink) Old 02-22-2015, 03:00 AM
stay away from WD...
the con lists is far longer than the pro list..
the big boxes and sporting goods stores carry TriFlow..
post #9 of 15 (permalink) Old 02-22-2015, 07:15 AM
TwoSkies57's Avatar
stuff I use comes out of Grainger. Simply called "dry lube". admit having no experience with the WD product..
here we go....
CRC dry moly lube
used it on large air handler outside air dampers for several years now. works great. no build up to speak of.
Skipper the Penguin
post #10 of 15 (permalink) Old 02-22-2015, 09:03 AM
First Name: Ellery
CRC dry molly lube is THE stuff for this application. Just a very light coating. It will
Also help in the prevention of rust. Clean the parts to be coated. It will flake off if
There is any oily film present.
Ellery Becnel
Arcola60 is offline
Stuck Router Bit Noj Router Bits - Types and Usage 11 07-21-2014 04:18 AM
Plunge Router Lubricant rick7938 General Routing 6 01-22-2010 02:05 AM
height adj lubricant ? awoodnut Table-mounted Routing 5 10-25-2009 09:09 AM
mortise bit lubricant ACV Tools and Woodworking 4 11-29-2007 09:17 AM
