What would be the best process for making these rings?? - Router Forums
post #1 of 15 (permalink) Old 02-26-2015, 01:53 PM Thread Starter
Country: Ireland
First Name: Tony
Default What would be the best process for making these rings??
Hi
What would be the best process for making these rings? I want to make them on a commercial level so efficiency is something I am after. Would it be a router table, jig, cnc or some other process.
Dimensions are inner diameter 18mm, outer diameter 23.6mm and thickness 28mm. Material would be top grade ply.
Any help would be greatly appreciated.
Great forums btw.
Name:	Gym rings sample pics 038.jpg
Electronut is offline
post #2 of 15 (permalink) Old 02-26-2015, 02:11 PM
kp91's Avatar
First Name: Doug
A router with a template, or circle jig is a pretty quick way of making these rings. The outside diameter could be rough cut fairly quickly with the band saw, taking a lot of work off of the router.
After the rings were cut, they will need to be rounded over with a roundover bit in a table.
A CNC machine would allow you to 'set and forget' the inital cutting, you could cut as many as would fit on the table of your machine. The rounding over could then be done by hand on a table.
The key is to find something to do with all of the inside cutoffs... If you are using a router circle cutting jig, you will end up with a hole in the center of the cuttoffs. With a CNC you will not.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #3 of 15 (permalink) Old 02-26-2015, 02:20 PM
Are you sure these are the dimensions? Maybe the thickness is 2.8mm. If so, seems pretty thin (fragile) to be made of wood, and even with good ply, a really soft touch would be needed, so maybe CNC (of which I have no first hand experience!) Can you use any other material than can be worked that thin?
jdonhowe is offline
post #4 of 15 (permalink) Old 02-27-2015, 03:57 AM
Phil P's Avatar
First Name: Phil
Hi Tony and welcome to the forum
Assuming that your dimensions are 180mm and 236mm x 28mm thick and that your are starting from sheet or planked materials then the obvious, albeit expensive, choice would indeed be a CNC router using a round-over bit. The first side could be machined on a flat bed spoilboard, the second side would need to be jigged up to keep everything in register, so a double-ended machine capable of pendulum machining (two different processes one at either end of the bed) might be the best option. On the other hand providing that you can break-down your materials into reasonable sized blanks using a wall or panel saw this job would also be feasible on either an automatic copying lathe, an automatic moulder (e.g. a Rye-type machine) or an overhead pin router. I can also see a method of using a modified engineering turret lathe to undertake the task instead of a copy lathe. Of these the pin router is the cheapest option, but is the most labour intensive, whilst the second cheapest is the Rye moulder. Whilst these are getting hard to come by these days, they are still a very useful semi-automatic mass production method which can be run at high throughput rates by semi-skilled staff.
I think you'd also need to consider some way to clean-up after machining, such as a tumbler for the outsides and a pneumatic bobbin (soft form) sander for the insides
Regards
Phil
Phil P is offline
post #5 of 15 (permalink) Old 02-27-2015, 08:09 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Despite routing being my thing, I would suggest that commercial quantities would be cheaper to farm out to one of the many firms that specialize in CNC or laser machining.
Harry
harrysin is offline
post #6 of 15 (permalink) Old 02-27-2015, 10:19 AM
If there is any kind of a market for these, I'd suggest you farm it out. Making your own will be extremely costly per unit. If you use ply, it will have to be Baltic Birch because the layers will show and anything less will not look very good because of gaps, etc.
They could be made from glued up stock. Buying up cutoffs and scrap is one solution, but you'll need to joint and plane them for uniform thickness before gluing them up, but that would allow you to leave the centers open so you have less waste. The look would be even more interesting than ply, and that could be a sales feature. The glue joints will hold forever and it will take an interesting finish. You could name them something like "Eco-rings" to stress that they are made of recycled material and are Earth friendly, that could justify a little higher price.
I guess it depends on what size enterprise you're planning. If you are very connected to the gymnastics community, you could make this a premium item. I always go upscale.
DesertRatTom is online now
post #7 of 15 (permalink) Old 02-27-2015, 11:09 AM
MikeMa's Avatar
My first guess is that they were turned on a lathe.
-Mike
Visit my woodworking blog: http://madermadeit.com/
MikeMa is offline
post #8 of 15 (permalink) Old 02-27-2015, 04:28 PM Thread Starter
Country: Ireland
First Name: Tony
So sorry, the radius should have been 180mm and 236mm respectively. While I said commercial quantities what I mean is the ability to make 20-40 a week with relative ease.
A decent circular router jig seems to me to be the most practical solution for my needs.
I have a good bandsaw and a jigsaw for the rough work but routers are a whole new world and the jigs to go with them even more so.
Of course the suggestion to outsource is always an option too but really at the end of the day my labour is free (to me at least) and someone else's is not.
Great feedback though thanks a lot.
Anyone else??
post #9 of 15 (permalink) Old 02-27-2015, 04:33 PM
RainMan 2.0's Avatar
My idea was the same as Doug's
Ok ,I never insulate
RainMan 2.0 is offline
post #10 of 15 (permalink) Old 02-27-2015, 05:31 PM
Phil P's Avatar
First Name: Phil
Ah, well, commercial quantities to me means 200 to 2000 a day, as you might have gathered....
I'd also consider that if you outsource the potential supplier would be looking to manufacture probably a minimum of 200 to 500 per style at any time. I used to sub-out bun feet to a guy with a hydrocheck lathe. He made no jigging charge or set-up per run charge, but his minimum quantity for any style was 250.
For small quantities like you are considering I think you'd be hard pressed to beat a lathe with a fixed profile knife mounted in the tailstock and a couple of mounting jigs. Routing 20 to 40 of these out by hand would soon become a major chore IMHO. Or maybe I just get bored easily
Regards
Phil
Phil P is offline
Router bits for Mortise and Tenon project? windhollowfarm Router Bits - Types and Usage 267 08-29-2018 11:19 AM
adding rings to router plate Goblu Table-mounted Routing 10 05-14-2014 11:20 AM
Growth rings and molding cuts Slomoe Table-mounted Routing 2 12-17-2011 07:02 PM
routing rings to make a hollow cone brucegseidner Router Bits - Types and Usage 6 04-16-2010 11:56 PM
MFD Rings Glue? silentblackhat Tools and Woodworking 7 12-27-2009 08:45 AM
