How to cut this? - Router Forums
post #1 of 18 (permalink) Old 03-11-2015, 06:50 PM Thread Starter
Country: Argentina
First Name: Pablo
Default How to cut this?
Hello fellow woodworkers, it's been some time.
Going back to my wood affairs, I have a doubt about how to cut this without needing a scroll-saw or a band-saw, I've attached the image showing it.
The dimensions: the big square is 20"x20" aproximately.
Artemix is offline
post #2 of 18 (permalink) Old 03-11-2015, 07:09 PM
First Name: Clay
What tools do you have and how perfect does it need to be? You could do it with just a jig saw, circular saw and finish with jigsaw, many different ways to do it depending on what you have to work with.
fire65 is offline
post #3 of 18 (permalink) Old 03-11-2015, 07:09 PM
The dimensions: the big square is 20"x20" approximately.
what is it you are wanting to cut???
the square, the notch or both???
the notch... Bosch jigsaw...
post #4 of 18 (permalink) Old 03-11-2015, 07:40 PM Thread Starter
Country: Argentina
First Name: Pablo
The notch.
Jigsaw, the material is hardboard, I will get one and practice a bit, I don't have one of those either.
Artemix is offline
post #5 of 18 (permalink) Old 03-11-2015, 07:48 PM
kp91's Avatar
First Name: Doug
a $3 coping saw will work as well, and then use a file to square the corner.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #6 of 18 (permalink) Old 03-11-2015, 07:49 PM
The notch.
no second rate saws either...
Bosch set the standards for the rest of the world...
JS572EL 7.2A Top-Handle Jig Saw Kit | Bosch Power Tools
and don't fudge on the blade either...
T-Shank Jig Saw Blades for Wood | Bosch Power Tools
post #7 of 18 (permalink) Old 03-11-2015, 07:56 PM
Pablo if you are going to do a bunch of these I would be tempted to stack a buch of the squares together and then clamp them and do all of them at once. I would use the skillsaw to cut kerfs almost to the finished width and depth and about every 1 to 1.5cm apart in between and router with a straight bit to the finished size.
post #8 of 18 (permalink) Old 03-11-2015, 08:11 PM
Semipro's Avatar
First Name: John_*
Geez, I wonder if you could do this with a router?
Semipro is online now
post #9 of 18 (permalink) Old 03-11-2015, 08:51 PM
N'awlins77's Avatar
First Name: Lee
Yea, router came to my mind first.
N'awlins77 is offline
post #10 of 18 (permalink) Old 03-12-2015, 05:27 AM
DonkeyHody's Avatar
First Name: Andy
I'm with Stick on the Bosch Jigsaw. Cheaper jigsaws are OK for the homeowner who will use it 3 times in his life, or if you simply can't afford the outlay right now. But if you can swing it, invest in the best.
You'd think that jigsaws have such a simple job - move a blade back and forth - that they'd be all the same. Not so. A good jigsaw is a joy to use, and will delay the time when you find it necessary to invest in a scroll saw or band saw. A poor one - well, it cuts wood.
DonkeyHody is offline
Triton 2000 & Depth Of Cut Of Saw Blade Gaia Tools and Woodworking 4 10-22-2010 06:41 AM
jig to cut off the brass guides bobj3 Jigs and Fixtures 8 08-26-2010 08:20 PM
How to cut slots in 2 pieces that are not straight on outsides. Midnight Shadow General Routing 4 07-26-2010 11:04 AM
Squaring plywood panels ShaneB Table-mounted Routing 46 10-14-2009 05:28 PM
Now, how I cut my tnons with a router. derek willis Table-mounted Routing 11 01-27-2009 09:51 AM
