Looking for 20" planer recomendations - Router Forums
 2Likes
post #1 of 11 (permalink) Old 03-14-2015, 06:51 PM Thread Starter
Jack Wilson's Avatar
First Name: Jack
Default Looking for 20" planer recomendations
I'm looking for a 20" planer, I'm not in a hurry but I would like to get one before summer. I doubt anyone here can do a side by side comparison, but if you can, that'd be great!
If you have, or have worked with, any planers this large please comment on the pros and cons of the particular machine you used.
I'm not brand loyal, just want a good machine with best features/price. I honestly don't know what features to look for so please educate me!
Thanks!
Jack
He is no fool who gives what he cannot keep to gain what he cannot lose
If you cannot stand behind our troops, (and I understand, no judgement here), then please stand in front of them, remember, they're willing to stand in front of you!
Jack Wilson is offline
post #2 of 11 (permalink) Old 03-15-2015, 06:19 AM
First Name: Larry
Its a good thing you have a big barn for your woodworking and vehicles, you already have 3 planners. Let me know what you get I might need to have you run something wide thru it. Your not to far away.
Knot working is offline
post #3 of 11 (permalink) Old 03-15-2015, 06:47 AM Thread Starter
First Name: Jack
Thanks for the heads up there Larry, I got rid of the Delta 12" planer a long time ago, just never took it off the list! So.... I only have 2 planers and truth be told I don't use the minimax for its planer, only as a 14" jointer. The Dewalt seems to give me a better finish. I put some carbide tipped blades on it, they do well but not as nice as the HSS, however the HSS would get nicked by hardwood, small knots, that kind of stuff, the carbide seems to be holding up much better, just not quite as sharp.
Jack
post #4 of 11 (permalink) Old 03-15-2015, 08:48 AM
I have had a Powermatic 209HH for 5-6 years and love the thing. It takes knots and squirrely grain like it was quarter sawn. Prior the that I had a Powermatic 15S. No comparison. I have yet to rotate the cutters on the 209HH.
The only minor "con" I have is the chip collection outlet. The 15S was at a 45 degree angle where the 209HH is straight out. It collects everything but the hose is more out of the way with the 15S. I just put a metal 90 degree elbow on the 209HH.
Because you asked. JimE
Jack Wilson likes this.
blackemmons is offline
post #5 of 11 (permalink) Old 03-15-2015, 09:17 AM
First Name: Buck
I just ran across some literature on the Woodmaster. It can be bought as a multi tool or just a planer. Their pricing looked good and it looks like a pretty rugged tool. I have no experience with them.
Buck
BOjr is offline
post #6 of 11 (permalink) Old 03-15-2015, 10:22 AM
I've seen the Woodmaster demoed at woodworking shows and it did a good job, partly because it has a DC voltage feed motor that can be set at any rate you want instead of the fixed speeds other planers get by powering the feed off the main gear box. You can also get moulder heads and sanding drums for them. If I ever upgrade from my 16" King I would probably go with a Woodmaster.
post #7 of 11 (permalink) Old 03-15-2015, 06:30 PM
First Name: Keith
I have a woodmaster it is a very good machine. I've had it for about a year. If I had it to do over I would more than likely go for a powermatic.
Woodshaper67 is offline
post #8 of 11 (permalink) Old 03-15-2015, 07:32 PM
Smile
Originally Posted by Knot working View Post
Its a good thing you have a big barn for your woodworking and vehicles,...
That's what I was going to say......
Sydney, Australia
jw2170 is offline
post #9 of 11 (permalink) Old 03-15-2015, 08:42 PM Thread Starter
First Name: Jack
And YOU'VE seen it, it's even messier now than it was then, plus I've got 3 trees drying out in there now. 2 maples and 1 white oak that I had quarter sawn. The maples are probably dry, they have been in there for almost or a little over 2 years, not sure which. The oak I just put in there this past fall.
Jack
post #10 of 11 (permalink) Old 03-15-2015, 09:02 PM
First Name: Dick
Four to five years ago I purchased a Powermatic 20" helical head planer as my first planer, the model number is a 209HH as I recall. It has seen pretty light duty. But it is used a fair amount for a full-time hobby shop. I have had no significant problems with it except that it got a little hard to feed at one point. I adjusted the bed rollers, which was not too difficult and it worked fine thereafter. I have indexed the cutters one time. However, I did not inspect them carefully before doing that. It did cut better after doing that. I am planning to make a melamine bed for it. Marc Adams has demonstrated that it works better that way, particularly with thin material. I am planning to cut my own veneer and plane it in this machine. The chips exit the machine satisfactorily to my Oneida Super Gorilla except they sometimes drop out into the stack of my wide belt sander. When my shop is rearranged I will take the chip producers (jointer, planer and Shaper) off the same line as the wide belt. The problem machine for dispensing chips is the 8" Grizzly Extreme jointer. It clogs up often, which is par for jointers according to Marc.
A friend of mine bought the same planer as me, because of my satisfaction with it. He is disposing of his 15" Delta planer, which is a bargain at $1,100.
rsumme is offline
wood planer grimreeper Tools and Woodworking 30 01-19-2015 09:41 AM
Planer help bergy Tools and Woodworking 4 12-08-2013 07:02 AM
Thinking Of Upgrading Planer Jerry Bowen Tools and Woodworking 23 06-14-2013 06:01 PM
Keep Those Rollers On Your Planer Clean Jerry Bowen Tools and Woodworking 10 04-17-2013 06:53 PM
Wonderful Wife (new jointer and planer) xplorx4 Tools and Woodworking 11 11-08-2009 03:29 PM
