Dead Makita 3612 BR - Router Forums
 5Likes
  • 1 Post By jeff423
  • 4 Post By RainMan 2.0
post #1 of 7 (permalink) Old 03-15-2015, 03:27 PM Thread Starter
First Name: Jeff
Default Dead Makita 3612 BR
My Makita 3612BR has been sitting for about 2 months. When I tried to use it yesterday I found it wouldn't start. I disassembled the switch and found that it's fine. Does this mean an open winding in the field - or is there some other possible cause?
How many ohms should the field read?
Thanks,
Jeff
jeff423 is offline
post #2 of 7 (permalink) Old 03-15-2015, 04:02 PM
RainMan 2.0's Avatar
Welcome to the forum Jeff . I'm not in a position to make much of a suggestion , but I believe others have had simular issues and I think it ended up being the brushes not seating right on the stator . I'm sure others will pipe up soon.
Ok ,I never insulate
RainMan 2.0 is offline
post #3 of 7 (permalink) Old 03-15-2015, 07:54 PM
Hi Jeff, welcome to the forum.
Sydney, Australia
jw2170 is offline
post #4 of 7 (permalink) Old 03-15-2015, 08:37 PM Thread Starter
First Name: Jeff
That was it. One brush was completely frozen and not touching the armature. I had to disassemble the router and pull the armature to knock the brush out from the inside. It and the channel were completely caked with wood powder. I cleaned out both channels with a round brush and wiped the carbon brushes clean with acetone. Works like a charm! Thanks for the help.
jw2170:
Thanks for the welcome. This looks like a nice place. I've been lurking for a while but this was my first post.
Jeff
BenAtar likes this.
jeff423 is offline
post #5 of 7 (permalink) Old 03-15-2015, 10:35 PM
jw2170:
Jeff
Holy crap I may have actually helped someone . Hallelujah !
post #6 of 7 (permalink) Old 03-16-2015, 08:52 AM
Welcome to the forum Jeff. Now you know there is no need to lurk.
post #7 of 7 (permalink) Old 03-16-2015, 11:09 AM Thread Starter
First Name: Jeff
Thanks,
I'll be more active in the future.
Jeff
jeff423 is offline
makita 3612 BR cromwell New Member Introductions 5 07-15-2013 08:30 AM
Base plate for Makita 3612 Harvoc Jigs and Fixtures 4 05-28-2011 09:49 AM
Makita 3612 collet nut and collet cone needed cheap Zappacat General Routing 5 07-18-2009 12:33 PM
