An Issue With The MJ Gripper - Router Forums
 1Likes
post #1 of 20 (permalink) Old 03-15-2015, 04:34 PM Thread Starter
First Name: Jerry
Default An Issue With The MJ Gripper
First of all, I will be the first to say that it is never ever a good idea to say anything negative about a product that is not proven to be true. So I want to be very careful to not imply that that there is anything wrong with the Gripper, I just had an experience that I need to ask a question about, so here goes.
I only recently purchased the basic Gripper then got the upgrade kit, the 1/8" leg, and the bridge handle.
This morning I installed the 1/8" leg which does not measure.125", but rather .160". Well what to do, just give it a try and see what happens but to be safe I set the height of the blade to barely cut into the top surface of a workpiece. In this case the workpiece was a piece of scrap cedar about an inch thick. I set up for the cut as close as I could and made a cut. Sure enough the blade took off part of the rubber pad on the inside of the 1/8" leg by about 1/16" high on the inside surface of the leg. Since the blade was set very low the leg was not ruined.
The thickness of the piece that was cut off was .156", not .125". the part of leg that the blade took off off the bottom edge of the rubber pad ended up being .105". I had taken off .055" of the inside edge of the leg.
If I had backed the fence off far enough to not allow the blade to contact the leg, the piece that would have been cut off would have been over .200".
Did I do something wrong, or am I being to picking expecting the leg to allow cuts similar to what is advertised and shown in the demos????
Jerry
Jerry Bowen is offline
post #2 of 20 (permalink) Old 03-15-2015, 06:56 PM
kp91's Avatar
First Name: Doug
Jerry,
I would talk to Micro Jig and see what they have to say.
Personally, If I were cutting 1/8 inch slices, I would cut them so they fall off on the outside of the blade.
But, if they advertise being able to do it, then see if they have any setup advice or any other comments.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #3 of 20 (permalink) Old 03-15-2015, 07:23 PM
Nickp's Avatar
First Name: Nick
Jerry...is it possible that the bottom of the 1/8" leg is angled away from the top where it's screwed to the body...? Meaning it might not be perpendicular to the table when it's against the fence ?
Nick
Nickp is offline
post #4 of 20 (permalink) Old 03-15-2015, 07:24 PM Thread Starter
First Name: Jerry
Originally Posted by kp91 View Post
Jerry,
Doug,
Yeah, up until now I have done my thin cuts on the left side of the blade and using the Incra LS system this has worked well, yes you have to re-set the fence for each cut but that isn't much of a probem. I just thought that I'd try the Gripper with th narrow leg. And yes, I will talk to the factory to see what they say about it, but it sure does seem to me that the leg is to wide at .160".
Jerry
post #5 of 20 (permalink) Old 03-15-2015, 08:09 PM Thread Starter
First Name: Jerry
Nick,
Sure is worth checking, but that won't account for the leg being what appears to be over size or what I think is over sized at .160" instead of something just under .125"
Kinda anxious to talk to the folks a the factory.
Guess I could just set the fence to 1/8" with the LS positioner and cut the leg to the lesser width after raising the blade to a height that would cut all the up the side of leg.
Jerry
post #6 of 20 (permalink) Old 03-16-2015, 05:47 AM
Nickp's Avatar
First Name: Nick
Originally Posted by Jerry Bowen View Post
Nick,
Jerry
Gotcha...anxious to hear as I just picked one up and haven't given it the same scrutiny...will check this weekend...thanks for posting this...
Nick
Nickp is offline
post #7 of 20 (permalink) Old 03-16-2015, 08:43 AM
Guest
First Name: Regis
Jerry,
I checked my nominal 1/8" side with my digital caliper; it is consistently 0.1130".
Regis
48394 is offline
post #8 of 20 (permalink) Old 03-16-2015, 09:14 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
I'm sure Jerry that if you were to post a few shots showing your exact setup, then the problem will be solved quickly.
Harry
harrysin is offline
post #9 of 20 (permalink) Old 03-16-2015, 10:37 AM
Jerry, my Gripper 1/8 leg measures .1125.
UlrichJ is offline
post #10 of 20 (permalink) Old 03-16-2015, 11:43 AM Thread Starter
First Name: Jerry
I ordered everything via phone from Microjig, but this morning, for the life of me I can't even find their phone number so, for now anyway, I can't make an inquiry, maybe later when I have more time to mess with it.
It's not important anyway, I have gotten along without for quite some time, but am courous.
I'll try to get some photos a per Harry's suggestion.
Jerry
IP Address issue bozee89 Lobby 2 08-13-2013 07:45 PM
mach2/3 +y multi-pass issue fireneuf CNC Routing 4 02-04-2013 04:16 AM
A Shipping Issue With Grizzly Jerry Bowen Lobby 12 05-13-2012 12:28 PM
New Table Saw Issue CanuckGal Tools and Woodworking 30 01-01-2009 08:46 AM
