Dust Collector Problem - Router Forums
 2Likes
post #1 of 15 (permalink) Old 03-25-2015, 08:29 PM Thread Starter
rrrun's Avatar
First Name: Henry
Default Dust Collector Problem
I've got a Craftsman 1-1/2 hp Dust Collector, model # 152.213370. My problem is that the on-board circuit breaker pops off every time I turn on the unit.
I tried starting it with none of the hoses connected, so there was no pressure on the motor for the draw (?) - no change.
I replaced that on-board 15amp circuit breaker - no change.
I inspected the wiring in the junction box - no obvious problems.
The unit began to not turn on easily a while ago, but I could get it running after a reset or two. Now, it just won't cycle up before the circuit breaker gives way.
The unit is not new by any measure, but age has no impact on performance in my home. So, age isn't it. However, I find Sears isn't selling replacement parts for it. Perhaps there's a clue there....
Any electrical geniuses out there able to keep me from spending money I don't have to replace this unit?
Henry
Santa Clarita, CA
www.MowryJournal.com
rrrun is offline
post #2 of 15 (permalink) Old 03-25-2015, 08:33 PM
RainMan 2.0's Avatar
This reminds me of an issue we had last summer in our headend . One air conditioning unit kept on tripping the breaker intermittently and they couldn't narrow down the problem till the motor finally blew .
Turns out the electric motor was the cause so your story has me wondering if it's the same thing
Your best option would be to measure the current draw with an amp clamp
Ok ,I never insulate
RainMan 2.0 is online now
post #3 of 15 (permalink) Old 03-26-2015, 07:13 AM
Motors draw alot of current on start up. Some fuses have time delay for this reason. If you replaced the breaker, you need to clamp the motor on start up and running, if you can get it to run. The breaker is probably tripping, because it is drawing high amps.
I'd check that everything turns and spins freely. Nothing wedged. Could be bad bearings.
Age does effect performance, despite what you may want.
Zerk is offline
post #4 of 15 (permalink) Old 03-26-2015, 08:42 AM
Contributor of the Month
PhilBa's Avatar
First Name: phil
I assume it was running fine prior to this. It could be a number of things but probably the motor. If no obstructions and it spins freely then check the starter cap.
PhilBa is offline
post #5 of 15 (permalink) Old 03-26-2015, 09:21 AM
First Name: Dennis
Craftsman -cut your losses now and buy a quality collector that will have service and parts available into the future. Yours is yet another example of what happens when someone buys tools of questionable quality thinking ,I won't use it much, it's plenty good.
Dennis
DaninVan likes this.
Tough as nails and nearly as smart
Good tools don't cost- they pay!
64 ford is offline
post #6 of 15 (permalink) Old 03-26-2015, 10:47 AM
MikeMa's Avatar
I am not an expert on electric motors, but my guess is that you have a bad starting capacitor on your motor.
Littlepete likes this.
-Mike
Visit my woodworking blog: http://madermadeit.com/
MikeMa is offline
post #7 of 15 (permalink) Old 03-26-2015, 12:40 PM
tvman44's Avatar
First Name: Bob
If you replaced the breaker with the proper breaker, then it is either a bad motor or starting capacitor if it has one. If it is the motor then it is time for a new unit.
Papa Bob
Using a couple of old Craftsman routers & a Bosch 1617EVSPK & a Dewalt DWP611PK Routers in SW Louisiana.
tvman44 is offline
post #8 of 15 (permalink) Old 03-26-2015, 06:58 PM
Everything runs fine, before it fails. It started tripping out, and then it got more frequent.
Does not have to be the motor, could be bearing, or fan binding.
Zerk is offline
post #9 of 15 (permalink) Old 03-26-2015, 07:15 PM
PhilBa's Avatar
First Name: phil
yup, that why I said "If no obstructions and it spins freely then check the starter cap."
PhilBa is offline
post #10 of 15 (permalink) Old 03-26-2015, 08:53 PM
BIG OLD TIM's Avatar
First Name: TIMOTHY
Henry: I am surprised the motor has not burned up by now. The fires thing that hit my mind was the motor connections are wrong for the input current. I went to the Sears Parts Direct site and entered the model number you provided and LO AND BEHOLD! the first thing I find is that this model is rated for dual voltage. That means the motor can be wired for 120 v or 240 v. With the slow start up and the breaker tripping, it screams low voltage! Low voltage means high amperage. Chances are that this unit came to you without a cord end or the person that sold it to you had a 120 volt outlet hooked up to 240 volts. I pity him if that's the case as he is going to burn up every thing he plugs in there. Open the wiring box on the motor and look to see if there is 4 wires coming from the motor and two coming in from the cord. May be three wires coming in and one will be the green or ground and should be connected to the motor frame. The wiring diagram is self explanatory as ling as the wires are still marked with the 1.2.3.4. markers from the factory. There appears to be no capacitor for this setup, although if there is then you need to take the motor to a motor shop and have them test the motor and mark the wires for you for 120 volt operation. Do not run this motor until you check the wiring! wrong voltage will burn it up in about 10 seconds or so, depending on the quality of the motor.
And don't let those fellas turn you off to Craftsman tools. It is pretty much true that you get what you pay for, but some of the "TOP" High Dollar ones, you are paying for nothing but the name. Some manufacturers do stand behind their warranties better than others. Sears brags about their lifetime warranty and truth be known its ONLY on hand tools that fall in a narrow group. Not power tools, not precision tools etc. etc. etc. so buyer beware.
Tim
BIG OLD TIM is offline
A Dust Problem rrrun The Finishing Touch 15 01-19-2015 10:44 PM
Index of Dust Collection Solutions and Comments allthunbs Shop Safety 28 03-14-2014 01:40 AM
My Dust Collection System MAFoElffen Tools and Woodworking 19 05-23-2013 03:39 PM
Dust Evacuation on Router Table Guitarman1 Table-mounted Routing 15 04-29-2013 01:51 AM
Dust Collection on Table Saw Router Table Extension Guitarman1 Table-mounted Routing 0 10-02-2011 02:32 PM
