Need some advice about a bit. - Router Forums
 3Likes
post #1 of 25 (permalink) Old 04-07-2015, 10:16 AM Thread Starter
Country: Argentina
First Name: Pablo
Default Need some advice about a bit.
Hi, I need a particular router bit to do a job on MDF, my previous one is burned, not sure why, maybe it was a bad quality or maybe I used too much speed.. who knows.
Alright, first things first, I need to make a groove on a 12mm MDF piece, and the groove is 30x100x9 (millimeters) 1.2x4x0.35 (inches).
So I need to make a jig for this, there is no problem in that, I got plenty of info about it. The problem is, I can't find a proper bit for the job, since I don't want to make too many passes, I'd like to use a 15mms (diameter) that fits into my router. (1/4").
What I can find is this one:
But since they are 6mms, so I would have to make a lot of passes. to finish the job.
Anyway, maybe that one will do, however MDF is very soft and easy to route.
You tell me what's my best option for this particular job!.
Thanks.
Artemix is offline
post #2 of 25 (permalink) Old 04-07-2015, 10:33 AM
Thanks.
too fast in the RPM's..
too much in a one pass bite...
feed rate too high or too slow...
bit is loading w/ the MDF's glue..
low router power...
all the above...
your measures... which one is which... (W/H-D/L)
width...
depth...
length...
are 1/4" shank bits all you can handle???
you have got to get you a dado blade...
http://www.freudtools.com/index.php/...shank=1%2F4%22
jj777746 likes this.
post #3 of 25 (permalink) Old 04-07-2015, 11:02 AM Thread Starter
Country: Argentina
First Name: Pablo
Yeah 1/4" and I also have an adapter for 8mms (1/3").
This is an image of what I need to do:
Artemix is offline
post #4 of 25 (permalink) Old 04-07-2015, 11:57 AM
see my Freud link...
post #5 of 25 (permalink) Old 04-07-2015, 12:05 PM Thread Starter
Country: Argentina
First Name: Pablo
Yeah, I saw that link, I think this one will do: Freud Tools | 1/2" (Dia.) Mortising Bit
Now I have to see if it exists here.
Artemix is offline
post #6 of 25 (permalink) Old 04-07-2015, 12:08 PM
another brand perhaps???
post #7 of 25 (permalink) Old 04-07-2015, 12:15 PM Thread Starter
Country: Argentina
First Name: Pablo
If that bit comes from Italy, it should be here I guess.
I have no idea about other brands, I've been looking for something like that lately but couldn't find anything, most of them are not "plunge", they just cut the profile.
Artemix is offline
post #8 of 25 (permalink) Old 04-07-2015, 12:28 PM
it's Italian made...
post #9 of 25 (permalink) Old 04-08-2015, 01:05 AM
Pablo you should be able to find 3/4" diameter straight bits in 1/4" shanks. Lots of companies make a bit in that size. 1/2" D should also be available.
post #10 of 25 (permalink) Old 04-08-2015, 08:34 AM
neville9999's Avatar
First Name: Neville
Send a message via Yahoo to neville9999
Pablo Seeing that you don't like to do too many passes then it may be that you cut too deep in one pass with your old cutter, The thing about router cutters is this, Don't buy cheap ones as they are not that good, buy a quality cutter and when it needs to be sharpened then get it sharpened, don't cut too deep in one pass as the cutter will get hot and burn, you will know if the cutter is working too hard, so don't cut too deep or too fast as you go along, good cutters are worth the time to take care of them, keep them sharp. N
old coasty and jj777746 like this.
neville9999 is online now
Getting started with router bits Mike Router Bits - Types and Usage 26 02-22-2015 02:23 PM
Advice on first bit GerryAttrick Router Bits - Types and Usage 9 01-18-2015 08:13 PM
STUCK BIT -- Bosch 1604A stuck with a 1/4" shank junky roundover bit corbind General Routing 27 02-24-2014 07:51 AM
Router Bit Set for Raised Panel Doors Hoss McGr Table-mounted Routing 8 10-17-2009 04:17 PM
RouterForums Amateur Night Rabbet bit Tables reible Router Bits - Types and Usage 1 10-10-2004 09:03 PM
