About the router bits adapter. - Router Forums
 1Likes
  • 1 Post By sunnybob
post #1 of 10 (permalink) Old 04-13-2015, 03:42 PM Thread Starter
Country: Argentina
First Name: Pablo
Default About the router bits adapter.
Hi, I was wondering, a week ago I went to a shop to buy some bits, and it seems like my router bit adapter is not very common, it looks like this:
http://imgur.com/OBJ6kDz
Are all like that?, or each router has a different adapter for the bits?.
Mine brought 2, one is exactly 1/4", and the other one is 8mm (1/3" aprox).
Artemix is offline
post #2 of 10 (permalink) Old 04-13-2015, 09:52 PM
Many are just like that.
post #3 of 10 (permalink) Old 04-14-2015, 09:33 AM
JFPNCM's Avatar
First Name: Jon
Make certain the adapter is for the router to be used. For example, one for a PC may not work for a DEWALT.
Jon
JFPNCM is offline
post #4 of 10 (permalink) Old 04-14-2015, 09:58 AM
First Name: Buck
I have a couple that look just like that.
Buck
BOjr is offline
post #5 of 10 (permalink) Old 04-14-2015, 10:05 AM
Shadowrider's Avatar
First Name: Scott
Yes, it's called a collet here in the states. I doubt seriously that they interchange between router brands as has been mentioned.
Shadowrider is offline
post #6 of 10 (permalink) Old 04-15-2015, 02:02 PM Thread Starter
Country: Argentina
First Name: Pablo
I see, so in other words, there is not such thing as a universal collet, and different brands have different collets. Another thing, are there collets that work as power drill chucks?, you know, collets where I can put router bits from a variety of shanks?.
Artemix is offline
post #7 of 10 (permalink) Old 04-15-2015, 02:44 PM
Each manufacturer designs the collet (thread, taper, etc.) to fit the motor shaft securely, so there is no "universal" collet.
A drill chuck design cannot hold a bit securely enough to be safe at router speeds. The collet needs to hold the shaft with as much surface area as possible.
While almost every collet (and bit shaft diameter) in the US is either 1/4" or 1/2", for other sizes you can buy a variety of collet adapter inserts such as this:
The outer diameter is usually 1/2", and the inner diameter is the same as your bit shaft.
jdonhowe is offline
post #8 of 10 (permalink) Old 04-16-2015, 12:50 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Drills apply pressure downwards, and turn at around 1500 rpm usually.
routers spin at anything up to 30,000 rpm (thats 20 times faster!) and the load is applied sideways as the wood is cut. Any type of drill chuck would come undone at that speed at sideways load. The result of that bit coming out at that speed could be lethal.
Most router bits are either 1/4 inch or 1/2 inch. But in metric countries there are also 8mm and even 12mm bits. Each would need its own collet (adapter) to be safe.
(1/2" translates to 12.5 mm, so a 12 mm bit would be loose in a half inch collet.)
paduke likes this.
sunnybob is offline
post #9 of 10 (permalink) Old 04-16-2015, 10:43 AM
One of our dearly departed members (passed away) used to use a router to drill with but he used an external speed control he said and figured that he might only be spinning at 1500 rpm.
post #10 of 10 (permalink) Old 04-16-2015, 03:10 PM
JFPNCM's Avatar
First Name: Jon
The easiest approach is to go for a Musclechuck and a 1/4" adapter from them.
Jon
JFPNCM is offline
Insert router bits subtleaccents Router Bits - Types and Usage 0 02-18-2014 08:59 AM
Router bits needed for Leigh Dovetail Jig D4R Llewellyn New Member Introductions 11 08-13-2012 03:04 AM
Replacement Router Bits for the Craftsman Router Crafter Brian in Burlington Router Bits - Types and Usage 1 11-17-2009 11:33 AM
How to buy router bits xplorx4 Router Bits - Types and Usage 31 02-09-2009 01:04 AM
