Planning to build a custom Biesemeyer long fence, any advices?. - Router Forums
post #1 of 7 (permalink) Old 04-25-2015, 12:48 AM Thread Starter
Country: Argentina
First Name: Pablo
Default Planning to build a custom Biesemeyer long fence, any advices?.
After giving it some though, I think that a Biesemeyer fence would fit my needs.
Now, I would need two of these, one 1 40 inches long and the other one 80 inches long. The question is, using the Biesemeyer construction method, would I end up with a solid guide?, I mean, with no play, robust, etc?.
I'm asking this because I never used one, and the videos I watched that show it are short fences, compared to the ones I would need.
Artemix is offline
post #2 of 7 (permalink) Old 04-25-2015, 09:45 AM
First Name: Robert
if you build right it will treat you well. I used aluminum instead of steel for mine, which I have one on my table saw and another on my router table and onced locked down u can push against the other end and it barely moves at all, like all my strength to make it defect 1mm, and I can't ask much more then that.
have fun building it
Strobe7 is offline
post #3 of 7 (permalink) Old 04-25-2015, 01:08 PM
First Name: Phillip
A forum member posted the below video a few days ago. It may be useful to you:
I'm not sure if I like the incremental positioning part, but you could always leave that off.
To change the world, change your mind.
phillipdanbury is offline
post #4 of 7 (permalink) Old 04-25-2015, 07:31 PM
Those aluminum extruded box sections are really nice. They allow attaching things like hold downs very easily but they are expensive. What you are suggesting Pablo is a plywood box section attached to a head that clamps to the rail on your saw. There is no reason why you can't make your own. I think the trickiest part will be attaching the box section to the clamp head. If you leave the end open so that you can have access inside for attaching washers and nuts to the bolts it shouldn't be too hard. The trick is to keep the fence square to the clamp head while you drill the holes to attach one to the other. The clamp head should allow some adjustment but you still have to be close to square.
post #5 of 7 (permalink) Old 04-25-2015, 10:34 PM
RainMan 2.0's Avatar
Wish I was a machinest as I'd build a tank of a fence . Would take a mini nuke to move it once it's clamped .
Panlo I had a Beis on my delta contractors saw but my new general saw is similar in design but has a kind of new twist , as the almunum face that guides the wood is removable so in theory a guy could buy some almunum and make a longer piece to attach. Take a look at Excalibur fences
Ok ,I never insulate
RainMan 2.0 is offline
post #6 of 7 (permalink) Old 04-26-2015, 12:33 PM Thread Starter
Country: Argentina
First Name: Pablo
Not too much used to metal work, but I think I will have to spend some time learning new stuff and buying new tools yay!.
Artemix is offline
post #7 of 7 (permalink) Old 04-26-2015, 02:10 PM
I was hoping by using extruded aluminum and a drill a guy could fab something up for the face of the fence . Seems to be all kinds of neat attachments for extruded aluminum when you see cnc router tables etc
Biesemeyer Fence hitnailonhead General Routing 8 03-29-2010 07:29 AM
Very Long Pivot Fence mcelduff Table-mounted Routing 2 01-12-2009 07:41 AM
Router Fence??? Need to build one!! ornan Project Plans and How To 4 03-20-2008 01:32 PM
Auxillary router fence for Biesemeyer table saw fence jcmmgm Table-mounted Routing 2 01-18-2008 10:48 AM
Sold: Biesemeyer Fence (new in box) deck99 Woodworking Classifieds 9 09-11-2007 10:37 PM
