Circular saws, distance from the border to the blade, is it universal?. - Router Forums
post #1 of 19 (permalink) Old 05-04-2015, 10:56 AM Thread Starter
Country: Argentina
First Name: Pablo
Default Circular saws, distance from the border to the blade, is it universal?.
Hi, I'm building a jig, and it would be great to know if the distance from the border of the platform of the circular saw to the blade is the same in every circular saw.
Based on the photos I saw, it seems that way, but if anyone knows for sure if thats the case, better!.
thanks.
Artemix is offline
post #2 of 19 (permalink) Old 05-04-2015, 11:08 AM
First Name: Jerry
thanks.
Pablo,
I do not know the answer to your question.
I can relate to what you are trying to do I think. Some time ago I purchased a guide for my circular saw from Rockler. I made an offset piece so that I can put the edge of it exactly where I want the cut to be. Then lay the guide next to it and after carefully squareing the guide the cut made with the saw is correct. The cut is in the right place and it is square.
Jerry
Jerry Bowen is offline
post #3 of 19 (permalink) Old 05-04-2015, 11:19 AM
No. They're not, and to add to the problem not all blades have the same kerf size, thin kerf blades for example, compared to a normal blade.
The rip guides aren't universal either.
You'd either have to incorporate an adjustment device, or pick one saw and build to suit.
Good luck, Pablo!
DaninVan is online now
post #4 of 19 (permalink) Old 05-04-2015, 12:25 PM Thread Starter
Country: Argentina
First Name: Pablo
Damn.. I feared that it was the case..
Thanks for confirming it.
Artemix is offline
post #5 of 19 (permalink) Old 05-04-2015, 12:37 PM
kp91's Avatar
First Name: Doug
If you check out Kreg, you might get an idea from theirs
https://www.kregtool.com/store/c48/s.../rip-cuttrade/
Even they say it fits "most" saws
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #6 of 19 (permalink) Old 05-04-2015, 03:11 PM
Doug; I bought one of those universal circ. saw rip guides for an older Makita but the fit is so sloppy (front to back) that I might as well throw it out. I bought it so that I could pass the saw on to my son-in-law; fortunately after buying this device I found the original Makita guide.
I hate getting 'ripped off'
post #7 of 19 (permalink) Old 05-04-2015, 03:22 PM
thanks.
I have two models of Milwaukee and Bosch... also Makita...
all measure differently...
post #8 of 19 (permalink) Old 05-04-2015, 04:03 PM
vchiarelli's Avatar
First Name: Vince
Pablo:
I can tell you that I have two circular saws, both Black and Decker, and the base offset from the blade is different on them.
I made a homemade jig (2 actually - one is 8 feet long, the other is 5 feet long) to break down large panels: 1/2 inch birch ply with a 3/4 inch guide fence. I made the fence over size, then cut off the excess with a circ saw to cut to an exact dimension for that saw. I labeled the two jigs with the saw name and specific blade I used, so I'm sure to use the correct saw.
I don't have a picture to post, sorry.
Vince
vchiarelli is offline
post #9 of 19 (permalink) Old 05-04-2015, 10:21 PM
JFPNCM's Avatar
First Name: Jon
Originally Posted by vchiarelli View Post
Pablo:
Vince
The best approach, make it to fit the saw and the blade, then label it.
Jon
JFPNCM is offline
post #10 of 19 (permalink) Old 05-05-2015, 05:29 AM
Also If you want a saw guide, it costs very little to make one out of three pieces of (say) ply. Loads of 'how to' on youtube. A simple wooden T saw guid will improve you cross cutting with it no end.
Fraise is offline
An Interesting Visit With A Lenox Band Saw blade Rep Jerry Bowen Tools and Woodworking 11 03-06-2019 06:32 PM
Laguna TSS. MAFoElffen Tool Reviews 12 08-12-2017 10:30 AM
Bosch JS572EL and JS572EBL jig saws Mike Tool Reviews 6 07-04-2015 06:05 PM
dado blade for spline joining sjonesphoto Tools and Woodworking 34 03-11-2014 11:11 AM
Circular Saw Blade SFPM Calculator MAFoElffen Dynamic Calculators 2 12-18-2013 02:24 PM
