gate upright spacing maths - Router Forums
 13Likes
post #1 of 24 (permalink) Old 05-07-2015, 02:59 AM Thread Starter
vindaloo's Avatar
First Name: Angie
Default gate upright spacing maths
I'm want to try to build a gate for the front of my house.
The problem I'm having is getting spacing of the vertical lengths worked out. For example, if the gate is 31 1/2" wide and I want 1/2" spacings, with each panel about 4" wide, is there some magical mathematical formula to work out the actual width of each panel?
Name:	gate problem.jpg
Nicknurse likes this.
When everything around you is going to pot, get out in the workshop.
vindaloo is offline
post #2 of 24 (permalink) Old 05-07-2015, 05:09 AM
boogalee's Avatar
First Name: Al
Angie
31˝ / 4˝ = 7 (31˝ = width of gate, 4˝" = panel + ˝" space)
Lose the extra 1/2" in spacing.
Al B
boogalee is offline
post #3 of 24 (permalink) Old 05-07-2015, 06:21 AM Thread Starter
vindaloo's Avatar
First Name: Angie
Originally Posted by boogalee View Post
.....Lose the extra 1/2" in spacing.
@boogalee
Ah, so I have an impossible calculation without losing the extra. That's fine, thanks Al.
vindaloo is offline
post #4 of 24 (permalink) Old 05-07-2015, 06:38 AM
Nickp's Avatar
First Name: Nick
...then .5/7=.071... This will give you the amount to add to each 1/2" space. Too small to worry about precision as the panels will shrink, etc... After they're installed.
You could drive yourself nuts by making a spacer .571...but that might take longer than building the gate...
Nick
Nickp is online now
post #5 of 24 (permalink) Old 05-07-2015, 07:25 AM
Your gate is 31 1/2" wide. Your slats are 4" wide and you want 1/2" spacing; here is the equation:
X= number of slats, then x-1 = number of 1/2" spaces (assuming you want slats flush at the ends.
Then 4x + 1/2(x-1)=31 1/2
4 1/2x - 1/2 = 31 1/2
4 1/2x= 32
x+ 7.111 Round down to 7 slats which leaves 1/2" left over, split the leftover 1/2" and inset both ends 1/4"
michmags is offline
post #6 of 24 (permalink) Old 05-07-2015, 08:21 AM
Garyk's Avatar
First Name: Gary
There is a French word "Trompe-l'oeil" used in art, furniture design and etc. that serve's well in your situation. The word means something that deceives the eye. So if your spacing pleases (deceives) the eye then you have got it right. Woodwork is a medium where small fractions of an inch really do not matter all that much. As someone above mentioned shrinkage and expansion is going to add imperfection anyway. Most of us call that "character". If your project is a tiny bit off no one will notice.
As an example I helped an engineer friend build a back porch on his home. It was built over an existing framework and was 30 foot long. Treated lumber was used and he drove himself nuts because it was 3/8" out of square. He spent over an hour trying to "find" the problem. The porch is still out of square and nobody knows but him, but it is a great looking porch. LOL
MT Stringer and Nicknurse like this.
Garyk is offline
post #7 of 24 (permalink) Old 05-07-2015, 08:41 AM
Another way is this: your pic shows 10 slats with 9 spaces. Your total width less 9 x the gaps equal how much wood there will be. Divide that by the 10 pieces. If you don't like the result try 9 pieces with 8 spaces or 11 pieces with 10 spaces. It's a little like calculating stair riser height.
DaninVan and Nicknurse like this.
post #8 of 24 (permalink) Old 05-07-2015, 09:12 AM
Angie
you have 7 panels @4'' and 6 spaces @˝''.. you need to loose/comp for .07 inches per slat... (kinda hard to float that much equally)
8 panels - seven ˝'' spaces would make for 3˝'' panels/slats...
w/ the panels flush to the the outside of the gate frame you will always have one less space than you have slats...
or one more slat than you have spaces...
take the total number of spaces and multiply by ˝''....
subtract that number from the width of the gate...
divide that number by the number of slats....
post #9 of 24 (permalink) Old 05-07-2015, 09:46 AM
First Name: Charlie
Send a message via Yahoo to Nicknurse
Ah, math....yuck....that's why I worked as a Registered Nurse....the calculations were done by the pharmacy department and the doctor. LOL
Nicknurse is offline
post #10 of 24 (permalink) Old 05-07-2015, 10:14 AM
MT Stringer's Avatar
Are the boards actually 4 inches wide? Or, are they actually 3 1/2" but called 1 x 4's?
MT Stringer is offline
Cutting Spirals without a spiral blade Ian1930elm Wood Scrolling 23 11-12-2014 09:43 AM
Peg Spacing jjmill1980 Tools and Woodworking 11 03-06-2012 12:51 AM
Baby Gate Design Help kawisser Project Plans and How To 4 02-13-2012 07:56 PM
Spacing question twisted bit Guide Bushings and Templates 1 12-04-2009 12:44 AM
Dovetail Spacing Calculations FlyMaster Table-mounted Routing 15 05-24-2007 04:30 PM
