Incra's Cross Cut Sleds - Router Forums
post #1 of 11 (permalink) Old 05-12-2015, 10:18 AM Thread Starter
First Name: Jerry
Default Incra's Cross Cut Sleds
I'm wondering if anybody has had any experience with the larger cross cut sled from Incra Tools.
I am not talking about their 5000 series. I have the standard Express sled that while it works well for what it is made for, it is to wmall for cuts up to about 27".
I phoned Mark Mueller about my need to be able to make cross cuts on a sled that are about 24". He put me onto and I ordered the parts for such a sled. I don't know the name of what I bought but the parts are all just like the express sled but much longer, maybe eight to ten inches longer.
I anybody can speak to this issue, I'd like to hear from them.
Jerry
Jerry Bowen is offline
post #2 of 11 (permalink) Old 05-12-2015, 04:26 PM
TwoSkies57's Avatar
Hey Jerry...
the 5000 can make cuts up to 25"s. I wonder if he suggested the panels used on the 5000 sled?
Skipper the Penguin
TwoSkies57 is offline
post #3 of 11 (permalink) Old 05-12-2015, 06:15 PM Thread Starter
First Name: Jerry
Originally Posted by TwoSkies57 View Post
Hey Jerry...
I'm not sure. I know that the aluminum piece that holds the panels is not the one for the 5000. The V27 will not fit on the 5000. I'm of the opinion that the panels are not the same as the ones for the 5000 and are made for to expand the Express Sled.
Jerry
post #4 of 11 (permalink) Old 05-23-2015, 01:52 PM Thread Starter
First Name: Jerry
I need some feed back from members that have the Express Sled or the 5000. I'm wondering how
how much of the side play you can get out of the aluminum plate that rides in the miter slots.
I measured the slots on my table with with a dial caliper which is not a real accurate tool but it's close
enough for wood working. I get a reading of .746", but the widest I can get the part of the plate
that rides in the slots is about .726". I cannot tighten the screws that create the expansion anymore
without breking something. This leaves about .020" of slop which is not all that bad, but am just
wondering if that is what others experience with their set up.
Jerry
post #5 of 11 (permalink) Old 05-23-2015, 03:51 PM
Ratbob's Avatar
First Name: Jeff
Jerry, maybe a little UHMW Tape to build up the rail thickness?
Ratbob is offline
post #6 of 11 (permalink) Old 05-23-2015, 05:00 PM Thread Starter
First Name: Jerry
Might work, but it doesn't answer my question as to what others
have experienced.
Jerry
post #7 of 11 (permalink) Old 05-23-2015, 05:03 PM Thread Starter
First Name: Jerry
Hey Jerry...
He did indeed, and that's what I got, but the sled, as I have stated is not limited to 25". I admit that cuts longer that 25" require holding the rear of the sled up so that it stays flat on the table, but what the heck, I have to be there anyway.
Jerry
post #8 of 11 (permalink) Old 05-23-2015, 06:03 PM
have experienced.
Jerry
I fixed two of the slides w/ the UHMW tape... lasted for years and years...
beat the snot out using the cams...
post #9 of 11 (permalink) Old 05-23-2015, 06:59 PM Thread Starter
First Name: Jerry
Now we're getting some place. What is UHMW tape? Where do you get it, and how did you apply it.
When applied, how much side play did you end up with. Sure sounds good to me.
Jerry
Just googled it, and will buy some, thanks Stick.
post #10 of 11 (permalink) Old 05-23-2015, 10:18 PM
apply it to the sides of the bar and not to the slot....
cut off bin to box to planter to--? JFPNCM Show N' Tell 12 08-27-2019 12:30 AM
Router bits for Mortise and Tenon project? windhollowfarm Router Bits - Types and Usage 267 08-29-2018 11:19 AM
Hello everybody iminabrons New Member Introductions 12 12-14-2014 12:01 PM
Using a cross cut sled DrillingThrough Starting Off 21 06-05-2014 10:50 PM
Cross cut sled for table saw S Bolton Jigs and Fixtures 19 01-28-2009 04:13 PM
