question about table top - Router Forums
 7Likes
post #1 of 15 (permalink) Old 05-13-2015, 07:03 PM Thread Starter
MT Born's Avatar
First Name: Dave
Default question about table top
I'm building my grandson a table for his playroom from 1X8 pine boards. I'm planning to use a kreg pocket hole jig to attach the 3 1X8s for the top. My question is should I glue the sides of the boards as well? Benefits or disadvantages?
Thanks!
MT Born is offline
post #2 of 15 (permalink) Old 05-13-2015, 07:18 PM
Thanks!
are the boards paneled together???
the pocket screws won't allow for movement... use these style clamps instead...
http://www.leevalley.com/en/hardware...,41309&p=40146
suggest splineing to put your top together...
post #3 of 15 (permalink) Old 05-13-2015, 10:46 PM
Were you thinking of using Kreg screws to attach the 1x8's to each other (edge to edge)? If so, it apparently can be done- Google "Kreg jig edge joining". I humbly suggest (as a man without a Kreg) that with good mating edges, wood glue and reasonable clamping technique, you'll get strong and tight enough joints that neither screws or splines are needed.
jdonhowe is offline
post #4 of 15 (permalink) Old 05-13-2015, 10:55 PM
3/4 material...
for rigidity, flatness and wood movement...
splines will be to Dave's advantage...
post #5 of 15 (permalink) Old 05-14-2015, 05:49 AM
Country: South Africa
First Name: Denis
Dave
You don't need splines. Edge-to edge gluing is stronger than the wood itself. Your problem is clamping the three boards together and holding them in accurate alignment while the glue cures. Use your pocket hole screws as a replacement for sash clamps. Just make sure you have a pieces perfectly aligned as you put in each screw - a long reach clamp over the spot as which you are screwing does the trick. Just make sure you are organised and can apply glue, clamp and screw two boards together within the open time of the glue you are using.
There are advantages to glue plus pocket hole screws. The glue results in a stronger joint than screws alone. The screws act as clamps and do away with the need for sash clamps.
Denis Lock - "Routing with Denis"
denis lock is offline
post #6 of 15 (permalink) Old 05-14-2015, 06:44 AM
Nickp's Avatar
First Name: Nick
Benefits...stronger joint, will keep better alignment over time
Disadvantages...tougher to keep perfectly aligned while clamping
The "two birds/one stone" in this is splines as Stick suggested. Helps with alignment during assembly and more forgiving with store bought boards...slight imperfections, etc...
Assuming you have the tools, of course. Couldn't tell from your profile.
Nick
Nickp is online now
post #7 of 15 (permalink) Old 05-14-2015, 07:56 AM
First Name: Dave
Biskets may be helpful as well.
D1schram is offline
post #8 of 15 (permalink) Old 05-14-2015, 08:35 AM Thread Starter
MT Born's Avatar
First Name: Dave
I was very clear with my question, but yes this exactly what I plan to do. Thanks for all the replies I think I will go with glue and the Kreg Jig.
MT Born is offline
post #9 of 15 (permalink) Old 05-14-2015, 08:56 AM
vchiarelli's Avatar
First Name: Vince
I think edge joining with pocket screws is overkill - I join edges with glue, use cauls to apply pressure during the glue up which also gets the faces quite even - minimal planing or scraping required.
To attach the top to the aprons, you could use the fasteners that @Stick486 suggested, but I prefer to use figure 8's. Easy to apply and allows for movement of the top with changes in humidity, etc.
Vince
Stick486 likes this.
vchiarelli is offline
post #10 of 15 (permalink) Old 05-14-2015, 09:36 AM
A long reach clamp is really important for keeping the faces flat and aligned. I have some cast iron body long reach clamps from Harbor Freight that I use for things like this. Not very expensive, but if you're using pre cut stock and not flattening it yourself, you are going to have real problems getting them aligned. I'd also make sure you joint the edges so they are flat as possible. Finally, don't forget to set the grain direction the opposite way every board so you don't get twists that multiply because of the grain. Here's a link to a discussion of this Table-Top Glue-Up Tips
Having had the experience, I don't think biscuits are much help over glue, glue and spline or glue and pocket holes. The third alternative is what I'd do.
I have a Freud LM74R010 10-Inch 30 Tooth TCG Glue Line Ripping Saw Blade that I use for ripping the unjointed side of a board like this. It gives a butter smooth finish that requires no further prep for gluing.
Finally, I'd be very picky about selecting pre sized lumber, particularly from a big box store. I'd go shopping after they've restocked after a very busy weekend, when the selection is best. I've looked through 50-60 pieces to find 3 or 4 that were flat, no twists, with no cupping or other major faults. Also make sure the grain alignment works on all 3 pieces.
That's my 99 cents worth on the topic.
DesertRatTom is online now
Positioning Router in Table Top Teddytim1 Table-mounted Routing 12 01-13-2014 07:05 AM
Favorite beginner base plate? rfsurfer Table-mounted Routing 43 12-31-2013 04:51 PM
Table Top Question UnionLabel General Routing 3 09-09-2010 08:43 AM
Second Cedar Top Table GoonMan Show N' Tell 7 09-19-2005 10:43 PM
