After market column/ cutter head locking for planers - Router Forums
post #1 of 11 (permalink) Old 05-21-2015, 05:51 PM Thread Starter
First Name: Phillip
Default After market column/ cutter head locking for planers
Hello all,
Several lunch box planer brands are incorporating column or cutter head locks into their lunch box planers to reduce snipe. I was wondering if anyone has tried to make a mechanism for their existing planer that locks the cutter head to the columns.
My local Home Depot carries the DW734, which has a mechanism like this. Just looking at the floor model, it's pretty simple. Has anyone thought about this?
Before considering this, I attempted to help the snipe problem on my porter cable planer by adding a 4' by 12'' torsion box that acts as infeed-outfeed tables. This helped but didn't solve the snipe issue.
To change the world, change your mind.
phillipdanbury is offline
post #2 of 11 (permalink) Old 05-21-2015, 08:20 PM
Funny you mention this; I was pondering this early today.
Why not just use a 12" wide by 8' L x 3/4' piece of plywood.
Lay your work on top of it and run it through.
As long as the plywood hits the rollers first it should eliminate that initial bump(?).
DaninVan is online now
post #3 of 11 (permalink) Old 05-21-2015, 08:26 PM
I have a Delta...same as the one in the picture. That lever on the side locks the motor unit in place, once you've raised/lowered it to where you need it. Is this the type of thing you're talking about? I've been bad about ensuring it's locked down after every adjustment...
post #4 of 11 (permalink) Old 05-21-2015, 08:48 PM
I have a 16" King and it will leave a little snipe even with the locks tightened. The problem is that when you start the board lifts one feed roller, and apparently the planing head partly, until the board lifts the second roller and then the head levels out until the board passes the infeed roller. At that point it tilts the other way. If you measure the length of the snipe you"ll find it is exactly the same length as the distance from the feed rollers to the cutting head. The only solution is if you can prevent the head from tilting when only one feed roller is making contact.
post #5 of 11 (permalink) Old 05-22-2015, 11:13 AM
Maybe it could be set up like Dan suggested ,make a sled to support the work ,then add a piece of sacrificial stock ahead and behind the good stock to take the snipe.
Herb Stoops is online now
post #6 of 11 (permalink) Old 05-22-2015, 12:48 PM
Ghidrah's Avatar
First Name: Ronald
The length of snipe from my planer is also equal to the diameter of the cutter head. I'll try and meas the span between rollers and CH to see if its the same. I always pushed a sacrifice through before and after. I also lowered my in/out feed rollers about a 1/4" and got a shallower snipe depth.
Ghidrah is offline
post #7 of 11 (permalink) Old 05-22-2015, 01:21 PM
Dan's suggestion was to put the board on top of a plywood sheet. That helps when you have a moveable planing head and a fixed bed with rollers. My King allows me to adjust those rollers on an eccentric so that no roller is above the bed or quite a bit is above. I leave mine down to avoid the problem Dan is suggesting a fix for.
Running multiple boards through does help eliminate snipe on some ends but my planner won't grip all the boards equally so some stall going through until the thicker one(s) pass through which leaves burnish marks on the stalled board so it often just causes a different set of problems.
post #8 of 11 (permalink) Old 05-23-2015, 11:12 PM Thread Starter
First Name: Phillip
Some people online suggest attaching runners to each side of a board that extend past the board's length on both sides. It requires nails, though, and I hate marking up new wood...
post #9 of 11 (permalink) Old 06-13-2015, 04:43 PM
projim's Avatar
First Name: Jamshed
I have tried all the tricks of the trade, still couldn't get rid of the snipe. Until I tried what Phillip suggested above but instead of nails on the sides, I used hot glue gun. It worked & was easy to pull out side rails.
projim is offline
post #10 of 11 (permalink) Old 06-13-2015, 08:26 PM
Ghidrah's Avatar
First Name: Ronald
I'd be leery, expecting hot glue to withstand the pounding of 2 to3 blades 20KPM.
Ghidrah is offline
Thickness planer cutter head comments kywoodchopper Tools and Woodworking 8 10-13-2014 10:52 AM
Profile Cutting Cutters and their Bearings neville9999 Jigs and Fixtures 7 12-10-2012 01:11 PM
The use of a Router table as a Profile Copier neville9999 Jigs and Fixtures 4 12-06-2012 11:44 AM
Locking Rabbet Joints using 1/8 slot cutter swgregory New Member Introductions 5 09-24-2012 10:35 AM
