Craftsman 5 1/8" Joiner/planer - Router Forums
 8Likes
  • 2 Post By BrianS
  • 2 Post By gmercer_48083
  • 2 Post By Herb Stoops
  • 2 Post By Stick486
post #1 of 10 (permalink) Old 05-28-2015, 08:13 PM Thread Starter
First Name: Tony
Default Craftsman 5 1/8" Joiner/planer
Has anyone ever retrofit another type of motor on a model 149.236321 craftsman joiner/planer? Motor lost bearing and no longer available. Willing to reposition motor external to base, but looking for suggestions. Old motor had a P/N of NL73523.
If this should be posted in another forum, please direct me to the correct URL.
Last edited by ukcats; 05-28-2015 at 08:16 PM. Reason: forgot to ask about other forums.
ukcats is offline
post #2 of 10 (permalink) Old 05-28-2015, 11:36 PM
BrianS's Avatar
First Name: Brian
Hi Tony. Welcome to our little corner of the 'net.
Just curious, where have you checked for bearings? If you've only checked with Sears, they have a reputation for not having parts stock for older machines. If there is an electric motor repair shop near you, I would check with them. Bearings are pretty standard items and chances are good they can cross reference for you and find one.
Barring that, you could check here:Old Woodworking Machines. Perhaps someone there can point you in the right direction.
Good luck, and do let us know how you make out.
DaninVan and Herb Stoops like this.
Brian
(Origin uncertain)
BrianS is offline
post #3 of 10 (permalink) Old 05-29-2015, 06:18 AM
First Name: Gary
Tony, I would remove the bearings (2) and check with a local bearing supplier to get replacements. To get a motor replacement, check with WW Grainger.
gmercer_48083 is offline
post #4 of 10 (permalink) Old 05-29-2015, 09:30 AM
I agree with Brian and Gary that you can replace the bearings yourself. Google local motor bearings and you will find one close by that can replace the bearings for around $20. and you can put them in yourself. I have done this several times,once with a Craftsman table saw motor. Sure beats several hundred for a new motor.
DaninVan and Stick486 like this.
Herb Stoops is online now
post #5 of 10 (permalink) Old 05-29-2015, 09:41 AM
Country: Mexico
First Name: Joseph Anthony
Arrow
+1 on that. here is pdf that can helps you:
http://vintagemachinery.org/files/PDF/FAQ/BearingID.pdf
RÖENTGEEP is online now
post #6 of 10 (permalink) Old 05-29-2015, 10:18 AM
maybe these will help..
http://www.electricneutron.com/elect...duction-motor/
File Type: pdf Bearing Handbook for Electric Motors.pdf (339.9 KB, 137 views)
Herb Stoops and jaguar1201 like this.
post #7 of 10 (permalink) Old 05-29-2015, 10:23 AM
Default Spring Cleaning
Welcome, Tony!
Change the brushes while you're at it, and belts if there are any.
DaninVan is online now
post #8 of 10 (permalink) Old 05-29-2015, 11:24 AM
Country: Mexico
post #9 of 10 (permalink) Old 06-08-2015, 08:59 PM Thread Starter
First Name: Tony
Thanks for all of the responses...since posting, I have added to my own troubles. While pulling the "toothed" pulley off the shaft, I broke the plastic motor housing around the bearing...my bad. I will certainly look at some of the motor suppliers suggested, but the motor is pretty unique in that it is a 7/8 hp "super small" unit that fits inside the planer/joiner. I think I can add an external motor under unit and make it work. I will post pictures of the retro-fit if I get it to work. Again, thanks for all the suggestions and posts.
ukcats is offline
post #10 of 10 (permalink) Old 06-08-2015, 10:14 PM
upgrade and do away w/ NPA Craftsman.....
for the acronym challenged... No Parts Available...
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
Craftsman really? brownsfn2 General Routing 25 07-18-2011 12:58 PM
dust extraction for craftsman routers headclansman General Routing 2 08-01-2009 10:29 AM
craftsmen router? rhe8542 Starting Off 21 04-20-2009 10:51 PM
Porter Cable vs. Craftsman rprice54 Tools and Woodworking 7 01-17-2006 10:16 PM
