Grizzly G0771 10" Hybrid Table Saw heads up... - Router Forums
post #1 of 3 (permalink) Old 05-29-2015, 09:16 AM Thread Starter
Default Grizzly G0771 10" Hybrid Table Saw heads up...
saw this elsewhere...
"Dear Valued Customer,
According to our records, you own a Grizzly G0771 10" Hybrid Table Saw.
We recently discovered that the motor pulley on this saw has an over-sized bore, which may prevent the pulley from securing properly to the motor shaft.
During saw operation, an improperly secured motor pulley and its machine key can come off the motor shaft and be thrown with great speed by the rotational force of the motor. If this happens, there is a small chance that the machine key can be ejected through the table opening and strike the operator or bystanders.
PLEASE IMMEDIATELY STOP USING THIS TABLE SAW! Do not use it again until the motor pulley is replaced.
We will soon send you a new motor pulley with step-by-step replacement instructions at no charge to you. Using the included instruction sheet, the motor pulley replacement procedure is easy and can be accomplished in less than 15 minutes-without needing specialized tools or mechanical skills.
We apologize for this inconvenience, but preventing possible injury to yourself or others is our top priority. If you have any questions about this notice, please contact us immediately.
Thanks,
Grizzly Industrial, Inc.
(800) 523-4777
[email protected] "
post #2 of 3 (permalink) Old 05-30-2015, 10:17 AM
Must have put a metric pulley on an imperial shaft? Or visa versa. LOL
Herb Stoops is online now
post #3 of 3 (permalink) Old 05-30-2015, 10:22 AM
RainMan 2.0's Avatar
Herb I think you called it
Ok ,I never insulate
RainMan 2.0 is online now
New Grizzly Router Table jdolan Table-mounted Routing 43 12-01-2013 04:45 PM
Ridgid R4510 10" Table Saw Upgrades GulfcoastGuy Tools and Woodworking 2 01-28-2013 08:15 AM
Router Grizzly Router Table bobj3 Grizzly Manuals 1 04-07-2012 08:53 AM
Table saw molding heads. Hankstains Tools and Woodworking 3 10-30-2005 02:28 AM
10" Craftsman Table saw given to me GoonMan Tools and Woodworking 6 05-06-2005 08:44 AM
