Crosscut Sled Zero Clearance Insert - Router Forums
 8Likes
post #1 of 16 (permalink) Old 05-30-2015, 09:39 AM Thread Starter
First Name: Mark
Default Crosscut Sled Zero Clearance Insert
Has anyone attempted or had success with retrofitting a tablesaw crosscut sled with a replaceable insert? I'm considering my options before committing to replacing the base. i can think of many issues that might come up keeping the insert flush, etc but it might be worth the effort. My base is 1/2 in baltic birch.
FreeTime is offline
post #2 of 16 (permalink) Old 05-30-2015, 10:16 AM
Al B Thayer's Avatar
First Name: Al
Just build the sled and make the cut. Then when it wears out just fill it with Bondo and cut it again. This can be done many times and makes for an accurate slot.
Al
The best things in life, aren't things.
Al B Thayer is offline
post #3 of 16 (permalink) Old 05-30-2015, 10:29 AM
Originally Posted by FreeTime View Post
Has anyone attempted or had success with retrofitting a tablesaw crosscut sled with a replaceable insert? I'm considering my options before committing to replacing the base. i can think of many issues that might come up keeping the insert flush, etc but it might be worth the effort. My base is 1/2 in Baltic birch.
yes...
flip it upside down...
set a guide for your router to the sled.. leave it be till finished...
rout a dado ¾'' wide or wider (wider is more gooder) by ¼'' deep centered to the saw kerf/slot...
add fasteners tthrough the base and into your cross bars about an inch from the dado to kill any hope of flex or movement....
change to a ½'' bit and through cut a second slot...
you should now have matching and opposing rabbets... a rebated/shouldered through mortise???
make ''T'' shaped filler out of Redwood, Cedar, VGF, hard Maple or White Oak (in this order)... Remember, the more vertical the grain the better...
concentrate on a snug fitting piece that is super flush to the top side... proud to the bottom by a fuzz is okay/good...
this a sneak up on it fit..
glue the piece in.. do your glue squeeze out clean up immediately...
that slightly proud to the bottom comes in really handy when you rig up some cauls to keep it pressed in...
use a smoothing plane or a LA block plane to flush up the insert...
I near rough cut the insert and then use a shoulder plane to achieve perfect fit...
1st time around.. an hour or so... once done you'll be able to apply what you have done here to other kinds of projects down the road...
viktor, Herb Stoops and mbar57 like this.
post #4 of 16 (permalink) Old 05-30-2015, 11:31 AM
On my shop made sleds I had a separate strip where the saw kerf is and when it wears out I remove and replace it. It starts out as one strip and goes to 2 when it is cut lengthwise.
Herb Stoops is online now
post #5 of 16 (permalink) Old 05-30-2015, 06:29 PM
TwoSkies57's Avatar
Here you go Mark...
I made one with a replaceable ZCI..
http://www.routerforums.com/twoskies...scut-sled.html
Skipper the Penguin
TwoSkies57 is offline
post #6 of 16 (permalink) Old 05-30-2015, 06:41 PM
Paladin's Avatar
First Name: Marc
[quote=TwoSkies57;660305]Here you go Mark...
The thread is still there, but the pics are gone. I am interested...any chance of posting the pics again?
Marc
Kenosha, WI
Paladin is offline
post #7 of 16 (permalink) Old 05-30-2015, 06:44 PM
TwoSkies57's Avatar
Try it again Marc... lots of pics, takes time to load...
Skipper the Penguin
post #8 of 16 (permalink) Old 05-31-2015, 09:08 AM
TwoSkies57's Avatar
Just to give you guys an update on this sled after 6 years of use. Only 1 design issue and its a biggie. The thing is a TANK. and weighs a bit more than what might be considered comfortable for alot of folks to use. The 2nd is that after 6 years, the walnut fence now has a very, very minor bow. Not much, but enough to make a degree or two error when using it for 90's. On narrow pieces, not such a big deal, but on wider stock, it adds up.
Herb Stoops likes this.
Skipper the Penguin
post #9 of 16 (permalink) Old 06-01-2015, 07:03 AM Thread Starter
First Name: Mark
Thanks guys for all the great ideas and input. Now I have to pick an approach Too many options
FreeTime is offline
post #10 of 16 (permalink) Old 06-01-2015, 12:46 PM
Country: Mexico
First Name: Joseph Anthony
Arrow
Maybe this helps you a little:
Gaffboat and Herb Stoops like this.
RÖENTGEEP is online now
Bench Dog Pro Plate and Zero Clearance Insert problem matt1710 Table-mounted Routing 24 07-17-2011 07:37 AM
Crosscut sled TwoSkies57 TwoSkies57 Gallery 22 12-14-2009 01:47 PM
Crosscut sled TwoSkies57 Show N' Tell 22 12-14-2009 01:47 PM
VIDEO - Shop built Mitering and Crosscut Sled johnwnixon Tools and Woodworking 5 09-06-2009 10:14 AM
guide to making zero clearance inserts ZCI blurry Tools and Woodworking 12 03-01-2009 11:13 PM
