I need a shop vac hose for a DeWALT DW618 router - Page 3 - Router Forums
 8Likes
post #21 of 28 (permalink) Old 06-12-2015, 07:20 PM
PhilBa's Avatar
First Name: phil
Ron, that's a sweet setup. Draging a hose is a real PITA.
PhilBa is offline
post #22 of 28 (permalink) Old 06-12-2015, 08:01 PM
Duane, be sure to read Ron's post about how he modified his sub base plate and got great results with his vacuum here:
http://www.routerforums.com/general-...ification.html
Ron, Why didn't you show the finished product? Nice jigs...
post #23 of 28 (permalink) Old 06-13-2015, 05:39 AM
First Name: Ron
Mike...didn't want to derail the thread!....
Guys, what you see there is truly all Mike's jig & template innovation...I hadn't picked up a router till this ongoing project came up, and couldn't have done it without Mike's (and Harry's) guidance!
Mike glad to see your clock is still keeping time!
Duane...spent the last 2 days routing, all those chips going overhead to the dust deputy/shop vac. 5 gal of chips nothing in the bag, nothing on the floor.
That said, you can see the cavities being routed on the bench, template over workpiece...since the subbase nearly covers the cavity, those chips have nowhere to go but up. YMMV depending on what & how you're routing.
Ron
rpludwig is offline
post #24 of 28 (permalink) Old 06-13-2015, 11:31 AM
First Name: Brad
Originally Posted by jschaben View Post
....................................I have got the Bosch hose (vac005 IIRC) which is pretty good, not effortless by anymeans but pretty good. It fits my Bosch stuff great but no go on the GMC or deWalt.
This comment threw me off and is why I did not recommend the VAC005 hose. And yes, it does fit the Festool OF1400 using the 35mm hose.
Just remember what my father always said, " Half the people in this world are below average!", and everything in life will make a hellova lot more sense.
timbertailor is offline
post #25 of 28 (permalink) Old 06-13-2015, 02:28 PM Thread Starter
Duane Bledsoe's Avatar
First Name: Duane
Originally Posted by rpludwig View Post
Duane...here's some pics of the DW618, vac routed above setup...hose attachment is 1 1/2" ID, 1 3/4 OD...hope this helps some...
Ron
Awesome!!! Is that simply the hose connected to the adapter that comes with the router only? I will most definitely want to do that set up. I have the overhead room to do it also, 10' ceilings.
I hit the like button, but honestly there should be a love button to press on some of these posts. :-)
Duane Bledsoe is offline
post #26 of 28 (permalink) Old 06-13-2015, 09:16 PM Thread Starter
First Name: Duane
I have solved the problem. I decided to try one of those step adapters today, and cut it down so it isn't clunky, just so I could go ahead and use my routers with dust collection now, before I order a hose and wait for delivery. Who knows, maybe this was the intended design to start with on this item, to cut it to fit. All I know is it worked, and very well. Details below.
I bought a step adapter from Lowe's today for about $10.98 plus tax. It worked so well that I went back for a second one, and now I am planning to just get a couple more so all my Dewalt routers are outfitted with one of these, plus I will end up with some extra 2 1/4" vac ports for making other dust collection devices, such as an enclosure for my table router, or maybe something for my drill press.
This vac adapter is made of a flexible rubber, and easily trims with a utility knife. I cut the smallest segment off, and then, leaving segments two and three together, I separated them from the remaining larger end. This is all that's needed to adapt my smaller shop vac hose to my routers, and it's a good firm snug fit, but comes apart easily with a little twist when needed. Cutting the smallest segment off still left an opening that was too small in the narrow end of the piece I wanted, so I went up about 1/8" and trimmed away the part where they had overlapped, and that left me with the exact right sized opening to fit the adapter on the router.
This fits all my Dewalt routers, the DW618 plunge base, and the compact DW611 fixed and plunge bases, both. Absolutely perfect. And it did not end up clunky feeling at all as I had feared.
Since I was left with two of the larger ends, I attached them back to back, with four 1/4-20 screws and nuts, 3/4" long, and a thin foam gasket between them that I made using a peel and stick foam pad, available in hobby stores, just to keep any air losses down. I put this on my sliding miter saw, since the plastic vac attachment it came with doesn't stay in place very well. I put a hose clamp on it to hold it on, and the larger shop vac hose I have here fits into this very well, and stays in place snuggly.
I'm stoked. I have $25 in the things I bought today, and ended up with 3 vac adapters (miter saw, and two of my routers). I will get two more to finish off all my router bases so I don't have to pull them off and on as I switch between routers, and I will have enough left to make other things as well, using the larger ends that are left over.
post #27 of 28 (permalink) Old 06-14-2015, 05:40 AM
First Name: Ron
Duane, yes, connected to supplied DW adaptor...
looks like you solved your problem!
ahh, the valu of this forum cannot be overstated!
rpludwig is offline
post #28 of 28 (permalink) Old 06-15-2015, 09:13 AM
Yes, I believe that will work. The ad actually shows a picture of the hose connected to a Porter Cable router extremely similar to my DeWALT, and it has the same exact dust port as mine does. Thank you.
Happy to be able to help!
IRestore is offline
simple router table - attach vacuum hose to router box, or use Bosch dust adapter? achoox4 Table-mounted Routing 7 07-07-2014 04:01 AM
router tables / shop remodeling kywoodchopper Show N' Tell 11 02-04-2014 08:59 PM
Shop Vac Water Filter Soapdish Tools and Woodworking 15 01-25-2010 12:22 PM
