Need help with 5hp motor - Router Forums
 8Likes
post #1 of 31 (permalink) Old 06-19-2015, 11:33 AM Thread Starter
Jack Wilson's Avatar
First Name: Jack
Question Need help with 5hp motor
Hey guys and gals, I just acquired a used "nonworking" tablesaw. It's got a 5hp single phase 220v motor. Initially the motor was packed with sawdust and wouldn't turn. I cleaned that and replaced the bearings. Now it still doesn't always turn, or turns slowly and blows the breaker, (30 amp double pole), and/or turns backwards. There is evidence inside the cabinet that @ one point the blade came flying off, probably due to the motor spinning backwards.
What would cause this?
Jack
He is no fool who gives what he cannot keep to gain what he cannot lose
If you cannot stand behind our troops, (and I understand, no judgement here), then please stand in front of them, remember, they're willing to stand in front of you!
Jack Wilson is offline
post #2 of 31 (permalink) Old 06-19-2015, 11:37 AM Thread Starter
First Name: Jack
Here's a pic of the tag
Jack
post #3 of 31 (permalink) Old 06-19-2015, 11:48 AM
That small writing at the bottom is the problem, it's passed its expiration date.
Herb Stoops is online now
post #4 of 31 (permalink) Old 06-19-2015, 12:02 PM
wiring on the motor for the CCW rotation...
not coming up to speed...
start cap no good...
start switch not engaging or disengaging...
Name:	WIRING FOR CW-CCW.jpg
File Type: pdf Maintenance and Troubleshooting of Electric Motors.pdf (68.0 KB, 87 views)
post #5 of 31 (permalink) Old 06-19-2015, 12:05 PM
Contributor of the Month
PhilBa's Avatar
First Name: phil
If there is no damage to the coils, I'd check the starter cap.
PhilBa is online now
post #6 of 31 (permalink) Old 06-19-2015, 01:28 PM Thread Starter
First Name: Jack
I don't see this motor reversing polarity, it's a random shift between the 2 directions. Sometimes it's clockwise, other times its not, just depends...but on what, I don't know.
Jack
post #7 of 31 (permalink) Old 06-19-2015, 03:25 PM Thread Starter
First Name: Jack
Coils LOOK good, how do I verify that they are?
Jack
post #8 of 31 (permalink) Old 06-19-2015, 03:39 PM
read the PDF's attached...
File Type: pdf How to check the Windings of a 3-Phase AC motor.pdf (235.4 KB, 189 views)
post #9 of 31 (permalink) Old 06-19-2015, 04:14 PM Thread Starter
First Name: Jack
Did a quick experiment, tried starting motor with leads reversed on capacitor, then tried starting motor with capacitor discuss connected. Both resulted in the VERY SAME SYPTOMS I have been experiencing right along. Also, when making an effort to discharge the capacitor, there were no sparks or arcing of any kind.
Jack
post #10 of 31 (permalink) Old 06-19-2015, 04:19 PM
PhilBa's Avatar
First Name: phil
well, that says it. I smell a cheap fix coming up.
Motor trouble shooting Stick486 Tools and Woodworking 3 09-01-2016 07:39 PM
decisions, decisions......booooosch! :) Duane Bledsoe General Routing 13 01-12-2015 12:56 PM
Stepper Motor Driver VS stepper motor controller robotdigg CNC Routing 24 03-31-2014 06:46 PM
name that motor (missing specs!) phillipdanbury Lobby 4 12-03-2013 07:07 AM
Peak HP dgcutter General Routing 22 01-10-2013 08:23 PM
