What's the largest torsion box that can be made? - Router Forums
 17Likes
post #1 of 45 (permalink) Old 06-28-2015, 11:30 AM Thread Starter
Duane Bledsoe's Avatar
First Name: Duane
Default What's the largest torsion box that can be made?
I have a Kreg work bench frame that measures 44" x 64". I need to make a top for it but having such a large span I worry about sagging through the middle. I have come up with various designs using 2x4 and center legs to prevent this but this will also make it very heavy. So far I am at 17-20 2x4's in the design, plus the top, plus the metal frame itself. I will need to move this later to do other work to complete my shop so this seems too heavy in my mind. So I was considering a torsion box top to keep it flat and lighter weight. Maybe all made from plywood and pocket hole joinery?
Duane Bledsoe is offline
post #2 of 45 (permalink) Old 06-28-2015, 12:00 PM
schnewj's Avatar
I would guess unlimited. However, there might have to be a proportional increase in material and construction thickness to prevent sag at some point.
Cherryville Chuck likes this.
schnewj is offline
post #3 of 45 (permalink) Old 06-28-2015, 12:29 PM
hollow core doors are essentially torsion boxes and they can get pretty big...
timbertailor likes this.
post #4 of 45 (permalink) Old 06-28-2015, 12:47 PM
First Name: Mark
If you are concerned with the potential weight - 2x4s are probably over-kill. I probably shouldn't comment on this because I used 2x4s in mine - convenience/availability and it was only a 30" x 4' table. You just need something that won't compress (i.e. height) - I suspect an internal frame using 3" tall pieces of 3/4in pine or plywood would give you just as much structural support. I can't imagine 1/4" thick x 1.25" angle iron will be bending or sagging much either
FreeTime is offline
post #5 of 45 (permalink) Old 06-28-2015, 01:10 PM Thread Starter
First Name: Duane
This is true, but they are vertical instead of horizontal, so I doubt they would have the same sag factor, but then again, they are only supported from one side by the hinges so maybe they actually have to be even stronger to resist sag. Hmm...
post #6 of 45 (permalink) Old 06-28-2015, 01:51 PM
Gaffboat's Avatar
First Name: Oliver
I believe aircraft wings are basically torsion boxes and each wing on the Antonov AN-225 Mriya (one of the world's largest aircraft) is over 130 feet long and supports three engines. I think you'll be pretty safe with anything you build.
Gaffboat is offline
post #7 of 45 (permalink) Old 06-28-2015, 02:09 PM
old coasty's Avatar
First Name: Bob
For the weight problem, a set of casters that lift off the floor when in place would work. Rockler has a set that will take 400 pounds.
old coasty is offline
post #8 of 45 (permalink) Old 06-28-2015, 02:26 PM
First Name: Brad
I made my own for portable work benches that use saw horses.
Just remember what my father always said, " Half the people in this world are below average!", and everything in life will make a hellova lot more sense.
timbertailor is offline
post #9 of 45 (permalink) Old 06-28-2015, 02:32 PM Thread Starter
First Name: Duane
Well, I have a concrete garage floor that is not level and even. I have to use adjustible feet to level it out, and then when I move it any rollers I use woud be up and down from each other instead of on the same plane. So I figure I'll have to just lift it.
post #10 of 45 (permalink) Old 06-28-2015, 02:40 PM
Duane, unless you are planning on rebuilding engines on your bench it shouldn't have a sag problem over a 5' span.
cut off bin to box to planter to--? JFPNCM Show N' Tell 12 08-27-2019 12:30 AM
More fun with box joints Gaffboat Show N' Tell 17 04-07-2015 09:27 PM
Christmas Jewelry Box kywoodchopper Show N' Tell 18 01-09-2015 08:34 AM
simple router table - attach vacuum hose to router box, or use Bosch dust adapter? achoox4 Table-mounted Routing 7 07-07-2014 04:01 AM
How to Make a Box learnexperience Tools and Woodworking 0 08-04-2011 10:30 AM
