belt supplier - Router Forums
 4Likes
post #1 of 20 (permalink) Old 07-04-2015, 11:58 AM Thread Starter
john60's Avatar
Default belt supplier
The belt on my jet 13" bench top planer broke on Wednesday. Ereplacement parts waned $44 plus shipping.
I searched around and found Beltpalace.com. I got two for $28 plus$5.12 shipping
Shipped priority mail and I got them yesterday
Such a deal
Herb Stoops likes this.
john60 is offline
post #2 of 20 (permalink) Old 07-04-2015, 12:12 PM
John, another option for the future is to use a link belt. This has the advantage of not having a memory of the typical belts. You can find it many places but HF has the best price I have seen.
post #3 of 20 (permalink) Old 07-04-2015, 12:52 PM
I use them on all my tools that need conventional V-type belts. not sure about the small belt driven power tools.
Herb Stoops is offline
post #4 of 20 (permalink) Old 07-04-2015, 01:01 PM
I have been thinking of replacing belts on my drill press, band saw, and table saw. Is the quality of the Harbor Freight belt equal to the belts from Rockler, Grizzley, etc? The HF belt is sure a LOT cheaper...
Dan3103 is offline
post #5 of 20 (permalink) Old 07-04-2015, 01:04 PM
Yes the only difference I have seen is the color is green.
I have used both and they are no different in my opinion, all seem to run smooth and never have worn one out or frayed .
post #6 of 20 (permalink) Old 07-04-2015, 01:10 PM
if your tool has a vibration and you install this belt and the vibration is gone you could very well have masked issues that needed attention...
post #7 of 20 (permalink) Old 07-04-2015, 01:14 PM
Thanks for the heads-up , Stick.
post #8 of 20 (permalink) Old 07-04-2015, 01:31 PM
Thanks, Herb. 12 feet ordered!
Dan3103 is offline
post #9 of 20 (permalink) Old 07-04-2015, 01:40 PM
Thanks John, I'll have to check the out. I need one of those little ribbed flat belts for a spindle sander. I don't think the link belt would replace it.
post #10 of 20 (permalink) Old 07-04-2015, 03:06 PM
You are correct Charles; the link belt is only for replacing regular V belts.
Stick, the vibration can be caused by a belt that has dried out. Any time you change a belt is a great time to test any adjustments and be sure all the fasteners are tight. Last time I changed the blade on my table saw I found most of the fasteners had loosened. By checking I saved myself a LOT of trouble. A little ND Vibra-tite on the threads and they will not come loose like that again.
Replacing drive belt on Delta 22-560 Thickness Planer storyman53 Tools and Woodworking 5 11-09-2013 07:28 AM
Hand held belt sanders RJM60 Tools and Woodworking 7 10-17-2010 05:31 PM
Makita Belt Sander kolias Tools and Woodworking 4 04-03-2010 07:46 AM
Link Belt vs V belt RobW Tools and Woodworking 8 05-06-2009 01:37 PM
Belt Sander --- hand held or benchtop? Drugstore Cowboy Tools and Woodworking 14 10-20-2007 01:41 PM
