Freud Dado Blade set? - Router Forums
 7Likes
post #1 of 31 (permalink) Old 07-06-2015, 07:33 PM Thread Starter
JudgeMike's Avatar
Default Freud Dado Blade set?
I'm about ready to push the buy button on a dado blade set. Looking at a Freud SD208 8-Inch Professional Dado set from Amazon. Just couldn't do so without checking in with my forum friends whom have all the good advice and wisdom.
I have a Grizzly G0691 Table Saw. Not sure what all I would use the dado set for. Probably start out by trying some box joints with my never used two year old Incra I-box jig. Hoping to get a decent set under a hundred dollars. Can anyone here with this model tell me to "Push It"? The buy button, that is. Or is there better for less? Thanks for any input... mike
JudgeMike is offline
post #2 of 31 (permalink) Old 07-06-2015, 07:43 PM
Mike, I have been happy with the Freud Red blades for many years. I am sure their dado sets should perform in a like manner. Do you have a dado insert for your table or are you planning on making one?
post #3 of 31 (permalink) Old 07-06-2015, 07:46 PM
RainMan 2.0's Avatar
I'd have to check but I spent big bucks so I hope my Freud dado is the same one . Only issue I had is I had to remove the blade lock in my cabinet saw as it was interfering with the little bolts that stick threw the back of the first blade . Mine has that knob on the outside blade to infinitely adjust the width . Very clever design
Opps sorry Mike I looked at the link and mine is much differant and and four times the cost
Ok ,I never insulate
RainMan 2.0 is online now
post #4 of 31 (permalink) Old 07-06-2015, 07:47 PM
I have that set...
good stuff...
very good stufff...
post #5 of 31 (permalink) Old 07-06-2015, 07:56 PM Thread Starter
JudgeMike's Avatar
Mike, my saw did come with a metal dado blade insert. I do however have several DIY blanks I made for zero clearance out of MDF. Thanks for your input!
post #6 of 31 (permalink) Old 07-06-2015, 07:59 PM Thread Starter
JudgeMike's Avatar
I have that set...
good stuff...
very good stufff...
Ahhhhh... I was hoping to hear something like your answer!
post #7 of 31 (permalink) Old 07-06-2015, 08:03 PM
mbar57's Avatar
Hey Mike, I just bought the DD208 set, which doesn't have all the bells and whistles that the SD set has, and I love it. Makes a nice clean cut, clean bottom, and comes with plenty of shims in various sizes to make a nice fit. I also think I paid about that price from my local big box, so that seems like a good deal as well. I wound up making my own insert which was actually easier than I thought, so I made zero clearance for my regular blade as well. Good luck, I think you'll be pleased if you push the button! I also wanted to mention that I made box joints with mine and found it easier than with my router, with just as nice results. That is just an opinion of course.
mbar57 is offline
post #8 of 31 (permalink) Old 07-06-2015, 08:03 PM
Ratbob's Avatar
First Name: Jeff
I have the SD208M set which is very similar. Works great, but the router's more fun!
Ratbob is offline
post #9 of 31 (permalink) Old 07-06-2015, 08:04 PM Thread Starter
JudgeMike's Avatar
Sounds like an interesting concept. Similar to a wobble blade?
post #10 of 31 (permalink) Old 07-06-2015, 08:07 PM
thanks...
so when are you going to ask about setting it up off the saw???....
Bosch 4100 EQUINOX400 Tools and Woodworking 23 09-16-2014 01:39 PM
Dumb table saw question Bill from Indy Tools and Woodworking 19 08-17-2012 03:39 PM
dado blade set versus router firstlight General Routing 10 06-11-2011 11:23 AM
FREUD Dado Sets sawstop Tools and Woodworking 11 05-01-2010 01:00 PM
Freud 99-266 rail/stile set jrcusic1203 Router Bits - Types and Usage 14 04-15-2009 10:03 AM
