Negative Rake on a table saw? - Router Forums
 5Likes
  • 3 Post By Stick486
  • 2 Post By Cherryville Chuck
post #1 of 4 (permalink) Old 07-08-2015, 05:55 PM Thread Starter
vindaloo's Avatar
First Name: Angie
Default Negative Rake on a table saw?
Looking to the future I've seen a good deal on a 250mm blade that will fit my TS. I know what negative rake is but am unsure if it can be used on a TS. It's -5* and I read somewhere that these blades were for mitre saws (no good to me in that respect) but other places mention TS blade.
Can it be used in a table saw or is it only for mitre saws?
When everything around you is going to pot, get out in the workshop.
vindaloo is offline
post #2 of 4 (permalink) Old 07-08-2015, 06:15 PM
if you cut plastics and aluminum...
some of the very hard woods that are prone to quickly dull cutters cut better w/ a negative hook angle.....
vindaloo, gearman and mbar57 like this.
"SNORK Mountain Congressional Library and Taxidermy
post #3 of 4 (permalink) Old 07-08-2015, 08:04 PM
One of the reasons for negative rake on a mitre saw is that it helps push down on the board during the cut. A high positive angle would tend to lift it and could be dangerous. Negative on a table saw will tend to lift the board but a 5* angle shouldn't make much difference. It's just something to be aware of while you are cutting. I would have to reference it to be sure but I think melamine and veneer cutting blades have zero or negative hook.
You can go to some of the blade manufacturer sites and look at the tables they have for what each of their blades are best at and the specs will sometimes include grind type and tooth angle. I think Forrest's site has a chart like that.
vindaloo and mbar57 like this.
post #4 of 4 (permalink) Old 07-09-2015, 05:18 AM Thread Starter
vindaloo's Avatar
First Name: Angie
Thanks guys. I did read it's good for veneered and melamine covered boards so it sounds good.
Just the info I needed.
vindaloo is offline
Fold down router table Gaffboat Table-mounted Routing 21 09-09-2018 06:41 PM
Yet another router table build ... JohnBFisher Table-mounted Routing 23 11-13-2014 11:33 AM
Incra table top arrived , now the fabrication part RainMan 2.0 Table-mounted Routing 9 08-12-2014 10:21 PM
Your wisdom is sought gcodom Table-mounted Routing 8 12-10-2010 07:03 AM
