Any shoe molding tips? - Router Forums
 18Likes
post #1 of 23 (permalink) Old 07-09-2015, 10:27 AM Thread Starter
First Name: Brad
Default Any shoe molding tips?
Getting ready to install shoe molding in the living room. My garage is full of stuff ready for the move so tool access may be a problem.
I was just going to use the RAS or the table saw with a miter gauge. The latter could get fussy with longer pieces.
I still mark the wall and floor side of the molding. I never seem to be able to keep track sometimes.
I have a simple miter box but no 22.5 degree slot. Tempted to go get one that does. Simple and you cut it as you see it.
Any tips or tricks like cutting backwards and upside down? Jigs for holding the molding in such a fashion?
Just remember what my father always said, " Half the people in this world are below average!", and everything in life will make a hellova lot more sense.
timbertailor is offline
post #2 of 23 (permalink) Old 07-09-2015, 10:38 AM
miter the OS corners...
cope the IS corners...
use a back saw w/ a miter box...
cheap and a very handy addition to the tool arsenal...
power tools may be too much... the RAS destructive...
post #3 of 23 (permalink) Old 07-09-2015, 11:14 AM
Using a brad nailer takes away the pain of trying to use a hammer on inside corners. For best results you can pre drill with a small bit.
post #4 of 23 (permalink) Old 07-09-2015, 12:18 PM
Originally Posted by timbertailor View Post
Getting ready to install shoe molding in the living room.......
Why 22-1/2°? The cut before coping a joint is typically made at 45° - unless you're planning to scarf joint sections to get longer pieces. A simple miter box like Stick shows can be easily modified to add another angle - doesn't matter if the angle is exact as you'll cut mating pieces with the same slot but with the pieces on different sides of the miter box. The downside is that one piece will be in the "correct" position (vertical surface flat against the inside face of the miter box) but the mating part will have the rounded toe against the face of the miter box - not a problem as these are typically smallish mouldings, you should be able to hold it in place with your hand while cutting.
Tom
tomp913 is offline
post #5 of 23 (permalink) Old 07-09-2015, 12:19 PM
Make your own miter box,very simple 2 sides and a bottom.
Lay out the 45deg. both ways and a 22.5 deg. both ways and cut them with the saw you are going to use. Make 2 boxes if you want one for each cut.
Have a 90deg. cut on one of them or use the end of the box for your 90's.
A pull saw makes an excellent miter saw, or a carpenter's handsaw, 10pt. or 12pt.
Backsaw is best if you have one.
use a coping saw to cope the inside corner, or make a coping jig for router table, like Gafboat Oliver did here on the forum.
Splice your long runs on a 45deg.
Brad nailers are great for running trim.
If the trim is going to be painted, pre prime or paint before you install it. you will be glad you did.
Herb Stoops is online now
post #6 of 23 (permalink) Old 07-09-2015, 12:20 PM
vchiarelli's Avatar
First Name: Vince
What Stick said.
Learning to cope inside corners is key - takes a while to learn but once you've got it figured out, works a charm. Practice on a few test pieces until it comes natural. Crown molding requires you to think upside down
Have your overlap on inside corners facing away from the traffic areas - that makes them less obvious. Hope that makes sense.
Same goes for scarf joints where required.
Sneak up on the finished length - you can always remove more material but you can't put any back on.
Brad nailer is a must - especially when working alone - and you don't have three hands.
vchiarelli is offline
post #7 of 23 (permalink) Old 07-09-2015, 01:24 PM Thread Starter
First Name: Brad
Originally Posted by tomp913 View Post
Why 22-1/2°?
Tom
Just the way the wall bumps out and how the corners are done in this contemporary home.
I am in a hurry, of course, and could not find a miter box with 22 1/2 degrees miter. Making one seems the most expedient method to solve this but with the garage in chaos for the move, not as fast a solution as one would hope. But, something I need to put on my jig list. I do have a back saw and several brad nailers. Reminds me to turn down the regulator.
I think I will just do the 22 1/2 on the table saw with the EB-3.
Coping not necessary, this is shoe molding. Simple 45 and 22.5 angles, inside and out.
post #8 of 23 (permalink) Old 07-09-2015, 01:37 PM
you have 45° corners???
Semipro likes this.
post #9 of 23 (permalink) Old 07-09-2015, 01:45 PM Thread Starter
First Name: Brad
Yep!!!!
Think about it. Chamfer a corner. You no longer have two mouldings with 45 degree ends. you now have three mouldings. Each with 22.5 bevels.
post #10 of 23 (permalink) Old 07-09-2015, 02:02 PM
you have round round then...
I need to make molding for drawer fronts stormbraceman Router Bits - Types and Usage 7 11-01-2012 06:40 PM
For Sale: Lonnie Bird's CMT crown molding set - Like new JeepCJ7 Woodworking Classifieds 0 04-16-2012 04:51 PM
Making Crown Molding thegaffer General Routing 5 03-03-2012 06:58 PM
Molding, molding, and more molding DPLRBruno Show N' Tell 6 04-07-2009 07:49 PM
