Cherry Fuzz - Router Forums
 7Likes
  • 2 Post By Stick486
  • 2 Post By PhilBa
  • 1 Post By Herb Stoops
  • 1 Post By Stick486
  • 1 Post By PhilBa
post #1 of 9 (permalink) Old 07-13-2015, 11:45 PM Thread Starter
Contributor of the Month
PhilBa's Avatar
First Name: phil
Default Cherry Fuzz
I built a table base using cherry for the aprons. I sanded it down in with 3 grits - 100, 150 and 220. Yet the wood on one side still had some "fuzz". If I ran my hand one direction with the grain, it's perfectly smooth but going the other direction (still with the grain), I could feel little splinters or some such. The wood isn't very figured. I used a ROS to sand so I went over it again by hand with 150 and then 220 taking pains to sand in the direction of the grain. it was a little better but I could still feel it. When I ran a clean shop rag over it in the one direction, you could see little threads that had been snagged. None of the other cherry boards I used for the project have this.
I put that side on the inside of the table and went ahead and finished so at least I managed to hide the problem. It still feels slightly rough even after 3 coats of General Arm-r-seal and sanding with 320 grit and then 600 between coats.
Any ideas on what I was doing wrong? It's driving me crazy (which is a short trip these days...).
PhilBa is offline
post #2 of 9 (permalink) Old 07-14-2015, 12:15 AM
flat or rift sawn woods are very prone do this...
the ends or layers of the rays (grain) are turned slightly up and those are why the fuzziness you feel...
hand sand w/ 120/150... use sanding sealer and don't sand to 220... max out sanding the the sealer at 150/180...
finer sanding is for between coats... no limit here...
too fine of an initial sanding will lend to a blotchy look in your finish......
the finer you initially sand the more fuzziness you'll suffer and the blotchier the finish...
chas980 and MYB like this.
post #3 of 9 (permalink) Old 07-14-2015, 07:24 AM
What about using scraper? Sanding sealer has also worked well for me whenever I've felt "fuzz."
post #4 of 9 (permalink) Old 07-14-2015, 08:51 AM Thread Starter
PhilBa's Avatar
First Name: phil
Interesting. I've always gone down to 220 and never had this before. A scraper might be a good idea. Worth a try. I did use a sanding sealer on this. (Which the guy at my local rockler said was a bad idea - I'm thinking he might be the bad idea)
Finishing is one of those areas that I kind of dread. I've got Flexner's book but there are still too many degrees of freedom, too many ways to completely screw up an otherwise great job.
TwoSkies57 and vchiarelli like this.
PhilBa is offline
post #5 of 9 (permalink) Old 07-15-2015, 06:48 AM
First Name: Phillip
After you apply several coats of varnish, sanding between coats, I don't think you should have any issue.
To change the world, change your mind.
phillipdanbury is offline
post #6 of 9 (permalink) Old 07-15-2015, 12:32 PM Thread Starter
PhilBa's Avatar
First Name: phil
Yeah, I did. No fuzzies but it's not as smooth as the other side of the wood.
PhilBa is offline
post #7 of 9 (permalink) Old 07-15-2015, 01:52 PM
When I saw the title of the thread "Cherry Fuzz" I thought it was a new Arctic Circle drink.
(Thats a joke son)
vchiarelli likes this.
Herb Stoops is offline
post #8 of 9 (permalink) Old 07-15-2015, 06:44 PM
I thought redhead...
Herb Stoops likes this.
post #9 of 9 (permalink) Old 07-15-2015, 09:44 PM Thread Starter
PhilBa's Avatar
First Name: phil
heh heh, reminds me of my first real girlfriend...
PhilBa is offline
Need help on Cherry stain Jimmy Ross Tools and Woodworking 8 11-23-2010 07:02 PM
Aging Cherry Using Artificial Light? BigJimAK Tools and Woodworking 13 09-06-2010 12:57 PM
Cherry Bowl BernieW Woodturning and Lathes 13 04-28-2010 10:21 PM
Finishing cherry with Waterlox the_nite_owl The Finishing Touch 3 04-21-2010 09:36 AM
What color of stain for cherry Jimmy Ross Lobby 0 03-28-2005 03:18 PM
