Belt slipping on my table saw. - Page 3 - Router Forums
 8Likes
post #21 of 25 (permalink) Old 08-23-2015, 10:35 PM
First Name: lee
Originally Posted by DaninVan View Post
Lee; was it necessary to replace the pulleys in order to use the link belt, or did you replace them because the existing ones weren't up to scratch?
Did you gain a noticeable increase in torque at the blade?
You do not need to replace the pulleys to use the link belt. I noticed the pulley on my motor side was not running straight so I decided to replace both pulleys. My table saw runs much smoother now. Glade I changed them.
DaninVan and vchiarelli like this.
coxhaus is offline
post #22 of 25 (permalink) Old 08-24-2015, 07:40 AM
Nickp's Avatar
First Name: Nick
Don...I'm pretty sure you need to adjust the entire motor bracket to tighten the belt by sliding the bracket in/out on the two large pins. Loosen the set screws, slide the motor mount bracket. Mount may be stuck on pins...take set screws out and shoot it with some PB Blaster...let it soak for a while and gently tap on a convenient spot on the mount. Don't bang on the pins...mushroom may occur...see item 6, page 38...
Nick
Nickp is offline
post #23 of 25 (permalink) Old 08-24-2015, 11:52 AM Thread Starter
hawkeye10's Avatar
First Name: Don
Nick the tension on the belt is the weight of the motor. Those two pins are to adjust the motor so it will not bottom out in the slot. I am talking about the slot in the bracket that holds the motor. If it bottoms out when you let the blade down the belt will get lose. When raising the blade if it bottoms out the blade will not go all the way up. That is the way I am understanding it.
I have decided to sell this saw and buy a better saw. I do appreciate everyones help and have tried fix it following everyones advice.
Don
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #24 of 25 (permalink) Old 08-24-2015, 01:33 PM
Nickp's Avatar
First Name: Nick
Don
Sorry you've had such a tough time with the Ridgid but best of luck and success with your new saw...
Don't forget to post all about your new toy...everybody likes to hear about new purchases...
Nick
Nickp is offline
post #25 of 25 (permalink) Old 08-24-2015, 01:39 PM
Nickp's Avatar
First Name: Nick
@hawkeye10
Don...if you want to take another shot at trying something, send me PM...will send you my phone number...it might be easier than posts...
Nick
Nickp is offline
Resurrected bird table Coleve Show N' Tell 16 12-07-2013 06:05 AM
Dust Evacuation on Router Table Guitarman1 Table-mounted Routing 15 04-29-2013 01:51 AM
Custom Ellipical Poker Table AzViper Show N' Tell 29 01-21-2012 02:41 PM
For Sale: RS 500 Router Table - routertabledepot.com sheridan Woodworking Classifieds 1 08-20-2009 09:51 AM
Converting Direct Drive to Belt Driven Table Saw don1 Tools and Woodworking 5 02-09-2009 05:11 PM
