Jig saw blade question - Router Forums
 10Likes
post #1 of 23 (permalink) Old 09-27-2015, 11:09 AM Thread Starter
Guest
Default Jig saw blade question
This has probably been asked a thousand times but I can't find an answer.
What is the best ALL AROUND blade for a jig saw in a wood shop?
I know that there are downcut and upcut blades of various TPIs. Each is best suited to specific tasks but I'm looking for a good general purpose blade to cut mainly soft woods and plywood no thicker than 3/4". I have neither a scroll saw nor a band saw so I need my jig saw to fill in for both.
Your thoughts?
By the way, my intent is to replace my old junky B&D jig saw with a a Bosch or DeWalt that has a blade guide, bevel table, orbital stroke, etc.
163481 is offline
post #2 of 23 (permalink) Old 09-27-2015, 11:57 AM
go w/ the Bosch.. you WILL NOT regret it...
FWIW.... Progressor wood blade for all around...
kp91 likes this.
post #3 of 23 (permalink) Old 09-27-2015, 12:15 PM
Gaffboat's Avatar
First Name: Oliver
+1 on the Bosch. The difference between it and your old B&D is incredible. I never had smooth, easy to control cuts until I switched to Bosch.
JFPNCM likes this.
Gaffboat is offline
post #4 of 23 (permalink) Old 09-27-2015, 12:16 PM
Your ability to scroll will be limited by the width of the blade. The narrower the blade the tighter the corners. At a point the blades get more fragile.
MAFoElffen likes this.
post #5 of 23 (permalink) Old 09-27-2015, 01:00 PM
exclude the Bosch scroll blades.... (101AO and 119B))
good things abound out there...
post #6 of 23 (permalink) Old 09-27-2015, 01:53 PM Thread Starter
Guest
I just took a critical look at my old jig saw for the first time in many years. I use it occasionally (rarely) but haven't paid much attention to it.
First off, I have unfairly maligned Black & Decker on here. The saw is a Skil, not a B&D.
The biggest problem with it is the blade guide. There are no rollers. It is just a slot in the sole plate that is four times the width of the blade. No wonder the blade twists and wanders. I just never paid attention to how cheaply it's made. And I can't find a detent on the sole plate to make it perfectly perpendicular to the blade. It's off by about 5 degrees.
I've gotta rectify this situation quickly.
I have rather large hands but kinda short fingers that have become arthritic and that leads to an additional question: Who prefers the D-handle and who prefers the barrel grip?
163481 is offline
post #7 of 23 (permalink) Old 09-27-2015, 02:02 PM
Bosch is your answer...
many to pick from...
the higher the number more the features..
Factory Reconditioned Bosch JS572E-RT 7.2 Amp Top-Handle Jigsaw
Bosch Jig Saws | Bosch Jigsaws
post #8 of 23 (permalink) Old 09-27-2015, 02:05 PM
schnewj's Avatar
I look at several jigsaws before I settled on my Bosch. Had the best features for the price. Reliable and easy to use.
Easy blade changes, fits my hand perfectly, easy to control with adjustments that look up solid.
schnewj is offline
post #9 of 23 (permalink) Old 09-27-2015, 02:06 PM
and Bosch CS is second to none...
post #10 of 23 (permalink) Old 09-27-2015, 02:10 PM
Here are some photos from when Brian and Chris tested the Bosch 572 jig saws. They both preferred the top handle model but I find I use the barrel grip a lot more for projects.
The Xtra clean cutting blades leave a finish so smooth you can often eliminate sanding.
jschaben likes this.
DadoWiz Jig setup question BeauxTi Jigs and Fixtures 10 07-05-2012 09:36 AM
Another Leigh Jig Question Famineguy Jigs and Fixtures 2 05-08-2012 07:55 PM
First Box Joints w/a Hart Design Jig Wild Rag Jigs and Fixtures 2 03-23-2009 08:54 AM
