Hot glue? - Router Forums
post #1 of 10 (permalink) Old 11-12-2015, 07:17 AM Thread Starter
hawkeye10's Avatar
First Name: Don
Default Hot glue?
Phil Thien's planer sled sounds like a good idea. He talks about using hot glue as shims. The hot glue I have dries really fast and there is no way I could do what he suggest as the hot glue would dry to fast. Is there hot glue that has more open time?
J. Phil Thien's Planer Sled
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #2 of 10 (permalink) Old 11-12-2015, 07:28 AM
Bodger96's Avatar
First Name: Bob
Hi Don I don't know the exact glue, but we use a commercial hot-glue (Still in Round Sticks) but it looks like a honey colour and takes a little longer to melt in a regular glue gun. We use a higher temp. commercial gun and I use it for all sorts of template work. It does have a longer open time than the clear or whitish colour sticks. I don't know if this helps.
Regards Bob
Bodger96 is offline
post #3 of 10 (permalink) Old 11-12-2015, 07:32 AM
schnewj's Avatar
Short answer, YES. Long answer, you can do a web search and find several different types of "glue sticks" that are used for different applications. They will range anywhere from hobbyist to professional uses. Some have different hold strengths, temperature flows, and open times. You just have to find what fits your needs.
schnewj is offline
post #4 of 10 (permalink) Old 11-12-2015, 10:06 AM
First Name: Ed
Her is a link to 3M's site they show different temp and times for hot glue
**Hot Melt Adhesives
herrwood is offline
post #5 of 10 (permalink) Old 11-12-2015, 10:25 AM
The darker the amber colour the stronger it is and higher the melting point. The working time is also decreased. The Bohning Company sells a stick of very amber coloured hot melt for attaching arrow points to wooden shafts but it is rectangular and meant to be used with a torch.
post #6 of 10 (permalink) Old 11-12-2015, 07:41 PM
Bill....
you forgot about this PDF....
File Type: pdf Ch09 ADHESIVE BONDING OF WOOD MATERIALS.pdf (436.9 KB, 90 views)
post #7 of 10 (permalink) Old 11-13-2015, 10:08 AM
Garyk's Avatar
First Name: Gary
Any problem with the glue leeching into the piece of wood ?
Garyk is offline
post #8 of 10 (permalink) Old 11-13-2015, 01:41 PM
Bodger96's Avatar
First Name: Bob
I have never had a problem and I have been using this technique since 1998. I keep a spray bottle with Methyl Hydrate (I believe in the US you call it Wood Alcohol) and a little spray and the template pops right off (it is almost like it freezes the hot melt glue). I have never had a problem with the Methyl Hydrate staining the wood.
Regards Bob
Bodger96 is offline
post #9 of 10 (permalink) Old 11-13-2015, 04:28 PM
Hot melt won't either. It is a surface glue, it doesn't soak in.
post #10 of 10 (permalink) Old 11-13-2015, 08:46 PM
w/ open grain/cell woods...
Hide Glue Daikusan Tools and Woodworking 9 02-11-2014 06:47 AM
Help: Hot Water System Gone Wild morgantruce DIY and Renovation 8 12-27-2009 07:40 AM
Hot melt glue to hold small parts for pattern routing? rstermer Portable Routing 22 06-22-2009 09:05 PM
