Festtool router - Router Forums
post #1 of 2 (permalink) Old 02-08-2005, 06:30 PM Thread Starter
First Name: Jiggs
Default Festtool router
Festtool OF 1400EQ router normally sells thru Festtool for 385.00 - now on sale for 350.00 - is their a better choice? I need another router - do I need this one?
Angus
angus is offline
post #2 of 2 (permalink) Old 02-08-2005, 07:16 PM
Angus, only you can judge which router will best fit your needs. Try looking at the many posts on choosing a router. There is loads of good information posted. Are you planning on using this router for home or commercial use? Will it be used 6 hours a day or a month? Are you planning on using the large panel raising bits on a regular basis? Will the router be table mounted or used free hand?
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
