Raised Panel Cutting Speed - Router Forums
post #1 of 3 (permalink) Old 02-13-2005, 08:25 PM Thread Starter
Question Raised Panel Cutting Speed
I recently obtained a raised panel cutting set and set up the 1 1/2 inch panel cutter in my Milwaukee 1 3/4 hp router on a table. The speed seems too fast and cutting action a little too excessive to be relaxed with. Am I doing something dangerous.
robert225 is offline
post #2 of 3 (permalink) Old 02-14-2005, 06:09 AM
Robert, any router bit spinning at 30K RPM is dangerous, but with due care and caution you should be fine. Use a safety guard over your bit, wear eye protection, and dont take off more than 1/4" in a pass. Make multiple passes to get to your finish depth. If you start cutting on the end grain and work your way around you should also reduce tear out.
post #3 of 3 (permalink) Old 02-14-2005, 02:17 PM
Most raised panel bits should be run at about 12K rpm. The bit manufactuer shold have the running speed listed. Reduce the rpms of the router.
Andrew is offline
Vertical Raised Panel Question rprice54 General Routing 23 03-15-2014 12:29 AM
raised panel router bits Dave2 Starting Off 7 03-30-2007 11:13 AM
What size of Raised Panel Bit? SandyT Table-mounted Routing 29 07-17-2006 11:34 PM
Question about raised panel router bits LBrandt Table-mounted Routing 2 07-08-2006 10:47 AM
research for raised panel doors presumed_druid Table-mounted Routing 4 01-13-2006 11:47 PM
