Ryobi plunge doesn't stay plunged! - Router Forums
post #1 of 4 (permalink) Old 02-18-2005, 02:07 PM Thread Starter
DHS
Question Ryobi plunge doesn't stay plunged!
Hi,
I have a Ryobi plunge router (the model number escapes me right now) that will not stay plunged. When it is turned on, it slowly rises up on the springs unless I apply firm downward pressure all the time. Well, I don't want to have to do that. Is there an adjustment that will give it a tighter grip? I have not found anything that looks like it would do the trick. I did check the spring tubes and they appear clean and not greasy.
Thanks for any suggestions,
Dan
DHS is offline
post #2 of 4 (permalink) Old 02-19-2005, 01:05 AM
Dan, does the plunge locking lever mover freely? Does it release ok?
post #3 of 4 (permalink) Old 02-19-2005, 09:34 PM
First Name: Paul
1/4", 1/2" what size and model? if it's a 1/2" with a locking mechanism in the handle - probably can adjust it. If it's a 1/4" with a paddle handle, probably not. If I'm on the right side with the 1/2", you have to disassemble the grip to adjust the locking mechanism.
hcbph is offline
post #4 of 4 (permalink) Old 02-22-2005, 11:18 AM Thread Starter
DHS
Hi guys, sorry for the delay, and thanks for the replys! I solved my own problem when I went to look at the model number. It's a #170, 1/4". It has a grip switch on one side, and a similar grip plunge lever on the other handle. I was looking at the model plate, when I noticed that one of the screws that holds the case together was located near the plunge lever, and the other side had no matching screw hole. "hmmmmm" I thought. Sure enough, that's the adjuster. It looks just like a case screw! That was the problem too - once I gave that a quarter turn, it locks up tight now.
Hopefully someone else can use this info someday.
Cheers, Dan
DHS is offline
plunge or fixed base bellaw Table-mounted Routing 16 01-08-2014 05:49 AM
plunge router? gweissbock Tools and Woodworking 5 07-31-2008 11:52 PM
Colt plunge base bobj3 Jigs and Fixtures 19 04-01-2008 08:54 PM
Freud 2200E -- How do I set it up for a measured depth plunge cut? Ladd General Routing 8 11-12-2007 04:23 PM
RE600 Ryobi Plunge Router Lee Brubaker Portable Routing 4 09-08-2006 10:03 PM
