Are T-track bolt heads 5/16? - Router Forums
 6Likes
post #1 of 11 (permalink) Old 03-06-2016, 09:10 AM Thread Starter
bryansong's Avatar
First Name: bryan
Default Are T-track bolt heads 5/16?
I've mounted some t-track to my table saw sled so before I make a run to the hardware store to get some knob and bolts I'm checking to see if my memory works, I seem to remember that 5/16" bolts fit that track. Is that correct?
Bryan
bryansong is offline
post #2 of 11 (permalink) Old 03-06-2016, 09:29 AM
sometimes...
other times and brands ¼'' fit better...
Buy Woodpeckers 1/4"-20 Oval Nut, 10 pack at Woodcraft.com
post #3 of 11 (permalink) Old 03-06-2016, 09:40 AM Thread Starter
bryansong's Avatar
First Name: bryan
Ok I guess My memory isn't so good, I'll take a closer look at my track. I bought it from Incra a while back.
I do have gold track but it's only one track (not like the one here) just the single. Buy Woodpeckers Plastic Knob Kit, 12 piece at Woodcraft.com
I do want this kind of knob set though.
Thanks Stick.
Bryan
post #4 of 11 (permalink) Old 03-06-2016, 09:51 AM Thread Starter
bryansong's Avatar
First Name: bryan
When all else fails, read the instructions. I just looked at the sleeve from I saved from Incra, and it says Standard 1/4-20.
I'm glad I asked anyway since Stick gave me that link.
Bryan
post #5 of 11 (permalink) Old 03-06-2016, 11:22 AM
First Name: Ellery
I really like the Multi-knobs. They seem to go on sale often Multi-Knob. You can use bolts or threaded rod with the nuts fixed in the knob. And they can be removed and switched. I have always said I love options. They are pretty also!
Arcola60 is offline
post #6 of 11 (permalink) Old 03-06-2016, 12:40 PM
Once in a while Lee Valley sells this kit for $39 but even at $49 it's a good deal. I bought one. 149-Piece Jig & Fixture Parts Kits - Lee Valley Tools
DaninVan and TenGees like this.
post #7 of 11 (permalink) Old 03-06-2016, 01:00 PM
First Name: Johnny
I built my sled from a YouTube video which had it set up to use 5/16” carriage bolts. I did not want to spend the money asked for regular “T” bolts so I used the carnage bolts.
That was a mistake because I tried using an off the shelf hold down which was ¼” and I could not find a “T” bolt long enough so I ended up using brass toilet flange bolts which come in both 5/16 and ¼. They are about a quarter of the cost of what the woodworking stores are charging. If I build another sled I will go with ¼” bolts all the way.
There is just no need to use anything more than ¼” unless you are milling steel.
Arcola60 likes this.
JohnnyB60 is offline
post #8 of 11 (permalink) Old 03-06-2016, 08:14 PM Thread Starter
bryansong's Avatar
First Name: bryan
Man, you had to give me the link to the Woodpecker site, I love that stuff. I saved that link for future reference. Thanks!
I did go to Westlake Hardware and picked up some 3" 1/4-20 bolts and knobs that will work for now.
I also saved the Lee Valley link. I might need it in the future.
Thanks guys.
Bryan
post #9 of 11 (permalink) Old 03-07-2016, 10:24 AM
I've used carriage bolts -- just use your grinding wheel on each side a little bit and they slide ride in.
HJ
DaninVan and Roy Drake like this.
honesttjohn is offline
post #10 of 11 (permalink) Old 03-07-2016, 10:54 AM
HJ
same here...
DaninVan likes this.
For Sale: Eagle-America Wooden Train & Track Kit Ray Newman Woodworking Classifieds 0 10-04-2015 04:42 PM
Anyone use a Festool track saw ? RainMan 2.0 Tools and Woodworking 39 07-03-2015 04:07 AM
accurate hexagonal holes for bolt heads steamingbill Jigs and Fixtures 19 04-20-2013 06:30 PM
A "closed-in" mitre track? matt1710 Table-mounted Routing 8 05-22-2011 07:27 AM
T track sourcing westend Tools and Woodworking 12 06-22-2009 11:56 AM
