How do I make cone shaped or tapered hole? - Router Forums
 23Likes
post #1 of 37 (permalink) Old 03-19-2016, 09:34 PM Thread Starter
First Name: Johnny
Default How do I make cone shaped or tapered hole?
I sharpened some of my chisels today and I want to make a holder for them to hang in but some of my chisels have tapered shafts. I made a holder for my craftsman chisels in 1971, but they were straight shafts. I lost a couple of them and bought Stanley which doesn’t fit my old holder.
JohnnyB60 is offline
post #2 of 37 (permalink) Old 03-19-2016, 09:36 PM
First Name: Keith
Maybe with a dovetail bit?
OK, fess up...which one of you clowns stole my sig? It was right here a second ago.
cocobolo1 is offline
post #3 of 37 (permalink) Old 03-19-2016, 09:40 PM Thread Starter
First Name: Johnny
Thats an interesting idea Keith. I hope you mean putting it into a drill motor because I'd be afraid to try to route it.
post #4 of 37 (permalink) Old 03-19-2016, 09:46 PM
First Name: Keith
Well, I think you could use a router on a new piece of wood...not on that holder that you have now.
Otherwise, you could use something like a Japanese saw, or even a dovetail saw to re-cut the one you have now. I think I would be inclined to make a new one, after all, you're going to need it bigger than that when you get that new set of chisels!
post #5 of 37 (permalink) Old 03-19-2016, 09:53 PM Thread Starter
First Name: Johnny
I was just looking through my router bits and found a bit with about the same taper, but not sure how to do it. I guess I could make two pieces on my router table and glue them together. I could then cut the opening after the glues dries.
post #6 of 37 (permalink) Old 03-19-2016, 09:54 PM
I'm not sure the shape of the hole would matter that much as the weight should hang by the base of the handle. If there is an issue with how well they stay on the rack then I would embed a 1/4" rare earth magnet in the body of the holder behind each blade. Lee Valley sells them cheap by the 10 pack and someone else posted a source for 100 that was dirt cheap.
post #7 of 37 (permalink) Old 03-19-2016, 09:55 PM Thread Starter
First Name: Johnny
I do plan on making a new one because I still think I may find my other craftsman chisels.
post #8 of 37 (permalink) Old 03-19-2016, 09:59 PM Thread Starter
First Name: Johnny
Thanks Charles, I just bought some earth magnets from Lee Valley, but if I'm going to use magnets then I would be better off using a magnetic tool holder which I might do
post #9 of 37 (permalink) Old 03-19-2016, 09:59 PM
PhilBa's Avatar
First Name: phil
Use a tapered reamer.
JohnnyB60, MYB, Semipro and 2 others like this.
Visit my shop website.
PhilBa is online now
post #10 of 37 (permalink) Old 03-19-2016, 10:05 PM
Semipro's Avatar
First Name: John_*
why not perdrill then use a step drill bit
Semipro is online now
Shelf pin hole jig - reviews and router solution Greg_R Jigs and Fixtures 17 04-24-2014 09:02 PM
Guitar Shaped Box jimcrockett Table-mounted Routing 20 04-13-2008 12:18 AM
router used as a cutter on a lathe max gersenson General Routing 17 09-10-2007 11:31 AM
Drilling large hole over small hole or vice-versa simplenik Tools and Woodworking 8 06-13-2007 08:57 PM
Routing a hole Learning Herb Tools and Woodworking 11 03-20-2006 05:29 PM
