Craftsman 10" 3HP Table Saw motor issues. - Router Forums
 9Likes
post #1 of 21 (permalink) Old 03-24-2016, 04:47 PM Thread Starter
First Name: Eric
Default Craftsman 10" 3HP Table Saw motor issues.
I admittedly have pretty much abused the machine over the years and it finally gave out on me. It would start, run for about 2 seconds then trip my GFI outlet or just lock up. I know nothing about motors and was going to just junk it since I have a brand new Bosch table saw and a Delta Cabinet saw and keep the stand/table for something else however I wanted to see if I could fix it so I took it apart.
The windings were all black from something that had been burning, I sanded the one brass ring down to clean it up. I checked the brushes, one of them gets stuck and doesn't come out. I cleaned them up, slapped everything back together and started it and it immediately locked up and smoked. Does this sound like a brushing issue? I'd hate to just toss out a machine someone else could get use out of or I could keep around as an emergency back up if its just a $10 part.
96BelisleAs is offline
post #2 of 21 (permalink) Old 03-24-2016, 04:54 PM
Chances are good when it started smoking that that was its dying breath. If it was locking up it may have been bearings which might have solved the problem, possibly. The smoking is a good chance of insulation on the windings getting too hot. A motor running under no load is using mostly voltage to turn. As the load increases it draws more current which heats the innards up. Too much cooks it and when it isn't turning or barely turning that happens very quickly.
post #3 of 21 (permalink) Old 03-24-2016, 07:56 PM
what type of saw is it???
portable or contractor..
direct drive or belt driven...
amp rating???
sounds like a cooked motor...
either the start switch or the start cap/windings went south...
the trip is either from overload or internal short to ground...
lean to internal short to ground..
see if these help...
gotta be sumptin in these PDF's...
File Type: pdf Diagnosing Electric Power Tools 101.pdf (386.8 KB, 130 views)
File Type: pdf Electric Motor Troubleshooting (Polyphase).pdf (850.1 KB, 54 views)
File Type: pdf Maintenance and Troubleshooting of Electric Motors.pdf (68.0 KB, 61 views)
96BelisleAs likes this.
post #4 of 21 (permalink) Old 03-24-2016, 08:02 PM
CharleyL's Avatar
First Name: Charley
When you let the magic smoke out of anything electrical, it's usually ready for the trash can. You are supposed to stop using it and fix or replace the offending pieces BEFORE letting the smoke out.
Charley
rrrun and Herb Stoops like this.
Central North Carolina
CharleyL is offline
post #5 of 21 (permalink) Old 03-24-2016, 09:12 PM
No Smoking in my shop.
Herb Stoops is offline
post #6 of 21 (permalink) Old 03-24-2016, 11:18 PM Thread Starter
First Name: Eric
amp rating???
Just got home, will have to check in the morning. It is direct drive. I know for sure one of the brushs is bad because like I mentioned the spring doesn't push one of them out.
Charley
It wasn't smoking until after I took it apart and restarted it. It was severely lagging and then started cutting off. However wasn't smoking. It smoked for a fraction of a second. I had my hand on the switch and hit it immediately. If its broke its not a big deal I just don't want to junk it if it can be fixed for $10.
post #7 of 21 (permalink) Old 03-25-2016, 07:44 AM
kp91's Avatar
First Name: Doug
If both brushes aren't making good contact in a universal motor it isn't going to run.
Does the motor turn freely when unplugged?
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #8 of 21 (permalink) Old 03-25-2016, 08:54 AM
smitty10101's Avatar
First Name: smitty
Send a message via Yahoo to smitty10101
If the winding are black you probably melted the shellac off the windings
Take the motor to a electrical motor shop for an estimate on a rewinding
probably about a $100.00 or so.
Look on CL for an equivalent one and R&R the old one
smitty10101 is offline
post #9 of 21 (permalink) Old 03-25-2016, 10:13 AM
Eric - If you decide to scrap it out, I might be interested in the rip fence and rails. I am the instructor for a wood shop class at a "Third Age Learning Center" for Seniors. We have a table say that has a broken fence. Rather hard to set! The saw table is 27 inches, front to back.
I would appreciate you keeping me in mind is you decide to dump it.
Breed is offline
post #10 of 21 (permalink) Old 03-25-2016, 10:59 AM
First Name: lee
Where can you find a place which can rewind the motor for $100? I just took my 1/2 hp drill press motor in and they want $600 to rewind it. I would like to get my motor fixed.
coxhaus is offline
Laguna TSS. MAFoElffen Tool Reviews 12 08-12-2017 11:30 AM
Advice on this Craftsman router and table needed! Brett K Table-mounted Routing 12 10-03-2012 01:24 AM
Craftsman router table help routafinger Table-mounted Routing 3 01-26-2012 08:23 AM
DIY Dust Collection on old Craftsman Routing Table 171.25444 TheCaptain Table-mounted Routing 2 08-10-2010 09:06 AM
Craftsman Router & Bosch Table camelracer Table-mounted Routing 13 01-19-2009 07:32 PM
